03-23-2017, 08:10 AM   #1
cdd29's Avatar
Light/sound activated trigger
Like many others, I try to do lightning photography when the conditions are right (safety included). I've seen several types of light, sound, motion activated triggers such as the Miops trigger and think it might be worth trying but none of the ones I've seen online seem to support the K-1. Does anyone know of one that would work with a K-1? I've emailed tech support on a few but haven't got an answer back yet.
03-23-2017, 01:44 PM   #2
klaus123's Avatar
A combination of Cactus LV5 and V5 or V6 would work for motion on the K1/K3 or in a dark environment a conination of Blub mode and flash triger might be even better (delay ~0)
03-23-2017, 03:50 PM   #3
Digitalis's Avatar
I use a laser trigger with a MIOPS* trigger, which can also be set off by sound and pretty much anything you can build a sensor for.
*i'm not affiliated with MIOPS - I just work with and happen to like their triggers.
dslr, full frame, full-frame, k-1, k1, pentax k-1, support
Is is possible to have a wirelessly activated bulb mode / interval shooting? Conqueror Pentax DSLR Discussion 7 04-20-2015 01:48 PM
How long until selling is activated after Donation? designinme_1976 Site Suggestions and Help 1 04-05-2011 09:51 AM
Remote trigger vs onboard k-x wireless trigger irishwhite Photographic Technique 3 03-06-2011 04:36 AM
Noise (like small motor running) while Live View is activated brosen Pentax DSLR Discussion 4 10-14-2009 10:01 PM
Noise while "live view" is activated Ivo Pentax DSLR Discussion 4 05-03-2008 06:36 AM
All times are GMT -7. The time now is 10:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
