I have been using Eneloop batteries for my Pentax af540fgz flash unit for a number of years with good results.
((i.e.: the batteries seem to be holding their charge well and easy enough to recharge)).
Well, I don't really like the little charger that came with the batteries because I never quite know if
all the batteries have charged properly/evenly?
The only thing that tells whether the charge has completed is that little green light that disappears once charging is done.
Would be nice to have something a bit "smarter", so I came across this:
https://www.amazon.ca/dp/B000RSOV50/ref=asc_df_B000RSOV504917040/?tag=shopbo...0&linkCode=df0
It apparently does the trick.
Anyone has been using this charger ? Any opinions/suggestions?
Thanks !!
