04-23-2017, 08:21 AM   #1
Your opinion on....
best Manfrotto tripod for low to the ground macro work?
04-23-2017, 08:27 AM   #2
ramseybuckeye's Avatar
Why Manfrotto, QR plates I assume?
04-23-2017, 10:46 AM   #3
LensBeginner's Avatar
I have a 190 series... the legs can fall almost flat, the center column can go at 90 and you can also reverse it (it's tricky and I'm not sure if it's an advertised feature or can just be done at your risk).
04-23-2017, 11:52 AM   #4
Alex645's Avatar
In a Manfrotto, hard to beat the 290 at $219:
Manfrotto MK290DUA3-3WUS 290 Dual Aluminum Tripod with 3-Way Pan/Tilt Head
For the same price, you can also opt for the same model but with a ball head:
Manfrotto MK290DUA3-BHUS 290 Dual Aluminum Tripod MK290DUA3-BHUS
And then if you want carbon fiber and can afford it ($477) then this 190 series is good, albeit the max and min heights are not quite as extreme as the aluminum 290ʻs.
Manfrotto 190go! Carbon Fiber Tripod with XPRO Geared 3-Way B&H
04-23-2017, 11:57 AM   #5
QuoteOriginally posted by ramseybuckeye Quote
If it's just the QR plate, a Manfrotto head would achieve that on any make of tripod. I use a Manfrotto "joystick" head on an Induro tripod. It has a centre column, which inhibits getting down really low, so I don't think my specific combo would suit the OPs needs.
04-23-2017, 12:29 PM   #6
I started with Manfrotto. Have one tripod and one monopod. Been happy with the quality but should have thought further ahead regarding getting down low. I like the quality of their products. Leaning toward the 190 xpro 4 section series.
tripod
Ask for your opinion of the old SMC Takumar 50mm 1.4 Bui Pentax SLR Lens Discussion 24 12-12-2016 03:27 PM
Would like your opinion on what I should sell digitaleagle12 Pentax SLR Lens Discussion 9 05-18-2016 05:38 PM
Your opinion on bacon... bertwert General Talk 44 04-22-2016 07:01 PM
MSI Cubi - need your opinion. UserAccessDenied General Talk 2 04-21-2016 03:47 AM
lens for K-50 (I want your opinion) NoobOnTour Pentax SLR Lens Discussion 15 05-21-2015 04:16 AM
All times are GMT -7. The time now is 05:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
