05-08-2017, 11:24 AM   #16
35mmfilmfan's Avatar
QuoteOriginally posted by csa Quote
I just hate to have a "makeshift" looking addition to such a beautiful strap
Sorry - what I have been told is a typical 'male' approach - functionality before looks. Neither is right or wrong, just different opinions.
05-08-2017, 02:34 PM   #17
jab2980's Avatar
I have the original Peak Design clip and it worked perfectly for me... either attached it to my backpack or to my belt. Nowadays I rarely go out without my tripod, so I don't use it. I'd also recommend the Cotton Carrier as it seems to fit your needs, but I've heard that friends don't let friends wear Cotton Carriers
05-10-2017, 09:13 PM - 1 Like   #18
csa
csa's Avatar
Update on my Peak strap. Evidentally the "grip" area of the strap, must have cardboard or something in it; as I put it in my backpack case for a couple of days; now there's a permanent bend in the middle of the reinforced grip area. Very disappointing for such an expensive strap. So tonight I went back to my OpTech strap.
05-11-2017, 04:35 PM - 1 Like   #19
What a drag - sorry to hear about that.
05-11-2017, 06:22 PM   #20
you might contact peak to see what they use but i'm guessing some kind of plastic
i'm assuming it sat in your pack with a sharp bend
you could try applying some gentle heat (hair dryer or heat gun) to see if the strap relaxes
05-12-2017, 11:30 AM   #21
csa
csa's Avatar
I won't mess with it. If I can't pack it in a case without it bending into a sharp crease, plus the uncomfortable sharp edge that irritates my neck; then it's not worth it to me. I just consider that I'm out $60! As far as contacting Peak, I tried; and even though I had filled everything out for contact, and went thru id'ing which pictures had cars, several times, it still would not process. Sorry Peak, but I'm very disappointed. Others may not have problems with these issues, so each has to choose what works best for them. Sadly, Peak isn't the one for me.
Live & learn. I'll stick with OpTech. They are located 90 miles from me; so a Montana company.
boss, tripod
Neck strap or hand strap? Both JimmyDranox Accessory and Memory Articles 21 07-18-2021 02:31 PM
To Strap or Not To Strap reivax Pentax Camera and Field Accessories 30 07-25-2012 05:32 PM
Recommendations for all terrain boots. Reportage General Talk 17 10-31-2010 12:44 AM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
Strap to replace standard strap Mann Pentax Camera and Field Accessories 14 06-03-2009 09:35 PM
All times are GMT -7. The time now is 09:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
