05-12-2017, 03:58 PM   #1
seemingly trivial Pentax LI90 battery question
Given two LI90 Pentax-brand OEM batteries, will the one with the higher number (printed in the silver box on the label) be the newer or older battery? There are several years difference in my batteries, but I don't know which is which. Or is it not possible to know (now)? Thanks.
05-12-2017, 04:03 PM   #2
Serial numbers are often not sequential. Are you able to tell by the wear on thr casing or contacts?
05-12-2017, 04:30 PM   #3
monochrome's Avatar
Don't the D-LI90's have dates on the underside?The one currently in my K-1 reads 201012, whic I interpret to mean manufactured 2010 December (12)
05-12-2017, 04:36 PM   #4
The batteries are very equally worn. I don't know how to decode the date if that's what it is: example SBCC. One is a K5 generation, other is K5ii.
05-12-2017, 04:45 PM   #5
jatrax's Avatar
All of my Pentax LI90 batteries have a date on the back. It is in the form "201502" or "yyyymm"
05-28-2017, 07:51 PM   #6
FilmORbitz's Avatar
QuoteOriginally posted by tibbitts Quote
Since the issue, I assume, is which battery is "better", just charge them both fully and measure the attained voltage. If similar, put them in camera for some equal amount of time/duty and again measure. The cream should rise to the top.
battery, li90, pentax li90 battery, tripod
Silly, trivial K-1 firmware question. pathdoc Pentax K-1 & K-1 II 6 03-27-2017 05:17 PM
Rainbowy glow around bright lights, but seemingly perfect SMC-M 50mm 1.7 pentytaxy Pentax SLR Lens Discussion 3 04-17-2016 01:43 PM
For Sale - Sold: Pentax D-BG4 Battery Grip for K-5 / K-7 w/D-Li90 battery Adam Sold Items 3 05-31-2013 01:05 PM
A very trivial info about DA 40 ltd Nubi Pentax SLR Lens Discussion 41 10-11-2009 09:58 PM
K-7 pdf manual vs. prerelease version (trivial) mattdm Pentax News and Rumors 3 07-03-2009 09:01 PM
All times are GMT -7. The time now is 10:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
