05-14-2017, 11:31 AM   #1
philodragon's Avatar
Double Lens Adapter Question (Canon to Pentax)
Hello all,
I am trying to find a way to use my Rokinon 8mm Canon Fisheye lense with my Pentax K5 (I switched from Canon to Pentax some years back). I have learned that there are no adapters for Canon lenses that would make them compatible with my K5. However, a friend mentioned using a Nikon adapter and then using a Canon adapter on top of that in order to make it compatible. Has anyone seen this work? Any drawbacks?
Happy shooting,
05-14-2017, 11:48 AM   #2
amateur dirt farmer
pepperberry farm's Avatar
wouldn't it be easier to sell the Canon lens and purchase a Pentax-mount lens?
05-14-2017, 12:02 PM - 1 Like   #3
boriscleto's Avatar
Just buy it in K-mount...We're not talking about an exotic lens...
05-14-2017, 01:41 PM   #4
Otis Memorial Pentaxian
To answer your question...it will not work for the same reason why a Canon-to-K adapter will not work.*
* Yes, they do exist, but Canon has a short registration distance meaning that an auxiliary glass element is required to attain infinity focus on cameras having a longer registration. This is true for both Pentax (M42 and K) as well as Nikon F.
05-14-2017, 02:57 PM   #5
Adapters can be had for Canon mounts that pre-date the EOS line. I have an adapter that will let me use lenses designed for the Canon Pellix and AE-1 lines.
I used to know why the EOS lenses couldn't be adapted.. but can't remember right now. The information is out there on the 'net somewhere.
05-14-2017, 03:02 PM   #6
It's not just the registration distance. Canon bayonets are wider than the others - the camera has a bigger "throat". Thats why other mounts (PK, CY, Nik F, OM) easily adapt to canon. The canon reg distance in shorter, and the other bayonets fit "inside" the canon bayonet. Just doesn't work the other way round.
The only way to go in these cases (other than getting a PK mount example of the lens, as already recommended, is a mount swap.
05-14-2017, 03:34 PM   #7
boriscleto's Avatar
QuoteOriginally posted by Heebie Quote
EOS has a wider mouth, shorter registration distance, and electromagnetic aperture. A corrected adapter would be pointless on an UWA or Fisheye because it is a short TC...
07-19-2017, 03:30 AM   #8
Tell me more pls as I have some bunch of Canon FD lenses. Were you successful to mount FD glass on Pentax body?
07-19-2017, 06:23 AM   #9
timw4mail's Avatar
QuoteOriginally posted by Prakticant Quote
They still require a glass element, and that leads to quite a cut in image quality. ( I have an FD to PK adapter, and a Canon 50/1.8)
So, not really worth it.
07-19-2017, 07:47 AM   #10
Some possible options:
Replace the mount on the lens:
Leica & Pentax & Nikon | Leitax
Replace the mount on the camera:
Pentax K+ Multi Mount - Adaptist
07-19-2017, 09:03 AM   #11
boriscleto's Avatar
The FD to K adapter is a short teleconverter (1.43x). It has a single corrective element and is just about useless wide open...If you take the corrective element out it becomes a short extension tube.
adapters for non-K-mount lenses to Pentax K-mount DSLRs: new dimensions for LBA - PentaxForums.com
07-19-2017, 12:27 PM   #12
THX, might be worth giving a FD 300mm/4.0L + K-3 a try, at least for fun
QuoteOriginally posted by boriscleto Quote
07-19-2017, 02:41 PM   #13
QuoteOriginally posted by altis Quote
Neither will work with Canon FD or EF (the mounts under discussion on this thread).
07-19-2017, 05:55 PM   #14
Lowell Goudge's Avatar
QuoteOriginally posted by timw4mail Quote
I have tried optically corrected canon FD to PK and Nikon AI to PK , depending on the optics quality they have quite a lot of color blooming at wide apertures, and are essentially teleconverters, the Nikon has a 1.25 X magnification ratio the canon about 1.45x from memory.
If you want soft blurry low contrast portrait lens it does the job but not much else
07-19-2017, 07:14 PM   #15
I've not had any issues with them. I'm sure there's degradation, as it's a relatively inexpensive adapter, but it's still reasonable. I did recently get "native" Pentax glass to replace the Canon lenses I was using. I could try shooting a few examples of K vs. FD adapted to K if I have the time and anyone would be interested.
adapter, adapter question canon, canon, k5, lens adapter question, pentax, tripod
Looking for a focusing rail that can double up as a nodal point adapter for 645D / Z r4heim Pentax Medium Format 4 03-23-2016 07:36 AM
Double Exposure: Canon vs. Nikon interested_observer General Talk 3 12-23-2011 06:35 AM
Pentax to Canon EF adapter question thorir Pentax SLR Lens Discussion 13 11-14-2011 11:07 PM
Nature Double Double-banded plover groom Kailash Photo Critique 3 02-04-2011 01:20 PM
All times are GMT -7. The time now is 04:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
