Originally posted by Bob 256 I just got my K-1 and want to explore some IR photography. Although the K-1 sensitivity to IR is low, it does produce pretty usable imaging with fast lenses and a time exposure. My main question is however, what is a good source for IR filters? I would like to get a source for thin film filters since one of my lenses requires a behind the lens filter and only a thin film would work. In looking at Wratten filters, I got sticker shock since my last purchase quite some time ago when they could be had for not that much. The 3 inch is going for almost $100US now!! I've got front-of-the-lens filters pretty much covered.
Anyway, suggestions would be appreciated.
I did try IR photography with IR72 filter on the lens and K-1. You allways need tripod, higher ISO, e.g. ISO 3200, f2,5 to acquire 1/13 second exposure time (not reasonable for mooving objects or mooving trees) and you can't see nothing through viewfinder. Just using LiveView. Quality of Live view picture is not good - too much noise. Pictures are little bit grainy.
The best way is converted Pentax APS-C camera. I did it by my self (K-30) - 640 nm filter. Simple glass filter costs about 20 euro S(tock Optics). If you are not able to do conversion yourself, there are servises available (about 150 euro maybe).
Here are some samples made with K-1:
http://www.efoto.lt/node/1185737 http://www.efoto.lt/node/1192454 (manipulation)
and witk converted K-30:
http://www.efoto.lt/user/56297/nuotraukos/serijos?serija=barcelona_infrared
