05-27-2017, 02:03 AM   #1
gzub's Avatar
What filter system for da 12-24
That's the question that I have. What system would be the best for da 12-24 ? I want to avoid the vignetting so was thinking that the 150 system from Nisi would be the best choice. What are your thoughts and impressions about it dear pentaxians ?
05-27-2017, 03:53 AM   #2
Nisi v5 filter holter has a 82 mm filter thread + adapter rings to 77. I suppose the 100 mm square filters are just ok. 150 and 180 mm are more expensive. I don't thik 100 mm filter would vignette with 12-24 unless you use many of those toghether. remember that with v5 the circular P.L. is bundled and by construction it does not take space
05-27-2017, 04:28 AM   #3
mattt's Avatar
I use a Cokin p frame. It vignettes wider than 15mm so don't use that one.
05-27-2017, 05:16 AM   #4
I use the nisi v5 82mm system (adapter to 77). Perfect. no vignetting whatsoever.. the filters themselves (100mm) are very good also.. very neutral.
05-27-2017, 10:06 AM   #5
I use 77 circular filters all the time on the 12-24. A thin profile Circular polarizer works great
05-27-2017, 05:02 PM   #6
Des
Des's Avatar
QuoteOriginally posted by Pentax Syntax Quote
Yes I use a Kenko Zeta which has been good.
05-28-2017, 12:29 AM - 1 Like   #7
gzub's Avatar
I will go for Nisi. That looks like a perfect match
07-09-2017, 09:46 AM   #8
Lee recommend their 100mm line. So far I trsut Lee for ther filter matching selector: LEE System Match - find the recommended System for each of your lenses.
Get Haida, I have no opinion about Nisi, but they seem fine. Cheaper systems often have one or the othrer problem.
09-01-2017, 12:08 AM   #9
gzub's Avatar
Will the other square filters fit to the Nisi V5 holder ? I found Hitech filters quite interesting and pricing is also more interesting than nisi filters.
09-03-2017, 07:30 AM   #10
QuoteOriginally posted by mattt Quote
A single-slot cokin P vignettes on that lens? That's surprising to me. It doesn't on my 77mm lenses, including the 10-20mm (old) Sigma at 10mm.
09-03-2017, 07:53 AM   #11
QuoteOriginally posted by gzub Quote
Yes, it should.
09-03-2017, 03:40 PM   #12
mattt's Avatar
QuoteOriginally posted by tibbitts Quote
Cokin CBP400A
09-03-2017, 06:07 PM   #13
Oh, that's three slots. But the 1-slot model (sorry I don't have the number) almost surely won't. I don't believe they made the one-slot model many years ago, so I cut the two front slots off with a saw for my 17mm lens (on 35mm.)
da, filter system, system, system for da, tripod
Samsung 12-24 ED Zenon same as Pentax 12-24 f4 MoparFreak69 Pentax SLR Lens Discussion 17 05-23-2021 03:55 PM
For Sale - Sold: DA 12-24, DA 35 , DA 40, DA 16-45, Sigma 18-250 - Only not sold -DA 16-45 now $150 TGaa Sold Items 11 05-04-2016 04:50 PM
Sigma 12-24 EX DG vs Pentax 12-24 F4 maxloxton Pentax SLR Lens Discussion 2 02-08-2016 08:00 AM
Sigma 12-24 vs Pentax 12-24 NaClH2O Pentax SLR Lens Discussion 5 01-19-2007 03:20 PM
All times are GMT -7. The time now is 11:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
