Originally posted by Aslyfox how do you hand hold 20 x binoculars and get a reasonably steady view at distance
I have a hard time holding 10 x
please pass on your technique as I am going to be at Yellowstone NP June 1
thanks
without sounding too glib...I just do
mostly what I find is that if I try to control the shakes they just get worse
so I allow whatever movement to just happen and direct it into a predictable pattern
at a distance the movement is gentle not jerky
at close range the jerkiness is amplified because the area being viewed is smaller
you've hunted...when shooting a high powered scope without mechanical assistance you cannot keep your crosshairs exactly on target
so you either shake and hope or develop a pattern (I use an oval/circle) and coordinate the coincidence of target, crosshairs and trigger pull
same as using a long, heavy lens
