06-27-2017, 11:11 AM   #1
Having problems removing Pan Tilt head from tripod.
I have bought a Gimbal Head for my long lens and need to remove the Pan Tilt head from the tripod so I can mount the Gimbal Head. No luck so far. Any suggestions are welcome.
06-27-2017, 12:00 PM   #2
jatrax's Avatar
Just speculation since I don't know what tripod you have (or what head for that matter)
1) Some heads are not removable at all.
2) Some have additional set screws underneath that need loosened first
3) Some have set screws or fasteners on the side that need to be loose first
4) Some just need a really big wrench
06-27-2017, 01:36 PM   #3
Otis Memorial Pentaxian
What he said ^^^
It might help if you were to share the brand and model tripod you are working with.
06-27-2017, 02:02 PM - 1 Like   #4
PEG Moderator
Kerrowdown's Avatar
I'll say it just in case... anti clockwise.
06-27-2017, 02:08 PM   #5
If you’ve already gone through what others have said and are sure you’re doing it right: a lot of times threaded parts are assembled with Loctite (basically glue). Sometimes there is a little bit of telltale blue around the screws.
Try heating the head up a bit with a hairdryer, that will soften the loctite. If you have an impact wrench, this would be the time to use it.
06-27-2017, 02:21 PM   #6
MSL
MSL's Avatar
I'd have to dig into my Manfrotto manual since I've only changed the head once, but something in the back of my mind is hinting that maybe the screws (not really screws but more like hex bolts) were reverse threaded. Including model details would help a lot.
06-27-2017, 04:43 PM   #7
Ex Finn.'s Avatar
My Manfrotto has 3 locking screws underneath to lock the head in place.
06-27-2017, 07:26 PM   #8
QuoteOriginally posted by Ex Finn. Quote
And the head itself will be secured by either a 1/4" or 3/8" stud (right-hand thread). With any luck @Big_Dawg will check back in with a report of success and/or a description of the tripod
06-28-2017, 03:48 PM   #9
Ex Finn.'s Avatar
And the head itself will be secured by either a 1/4" or 3/16" stud (right-hand thread). With any luck @Big_Dawg will check back in with a report of success and/or a description of the tripod
475B has a 3/8-16 stud. Gitzo 3542L has a reversible 1/4-20 3/8-16 stud.
06-28-2017, 06:06 PM   #10
Funny you should say that. The center platform on my Slik 330DX legs is notched on each side to accept some sort of plier. That would have come in handy today when I decided to take the head off. It took several tries despite the design not using any grub screws to fix the head in place.
Yes, I screwed up (bad pun and wrong fraction) and will edit. My Giottos uses a combo 1/4-20 3/8-16 stud while my Slik 330DX has a fixed 1/4-20 stud. The Manfrotto 494 head I use with the 330 DX is threaded to accept 3/8-16, but a 1/4-20 adapter (included in the box with the head) allows them to mate quite nicely.
head, pan, pan tilt head, tilt, tripod
For Sale - Sold: Manfrotto 055XPROB Pro Tripod with 804RC2 3-Way Pan/Tilt Head Curbster54 Sold Items 2 11-16-2016 11:54 AM
For Sale - Sold: 3-Way Pan/Tilt Tripod Head - Manfrotto 808RC4 (Worldwide) Ole Sold Items 3 01-19-2011 07:10 PM
pan-tilt head vs ball head raider Pentax Camera and Field Accessories 9 11-02-2008 09:13 PM
All times are GMT -7. The time now is 04:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
