I bought a Gitzo Traveler 2 kit a few years ago and have been fairly happy with it. However, recently I wanted a head which was Arca Swiss compatible so that I could keep my Peak Design plate on my K1. As Arca isn't represented in Russia, I found a Manfrotto head that was Arca compatible so I ordered it.
After I got it home, I found the head to be female but so is the Gitzo column! I thought they were all compatible with each other. What an idiot.
Does that mean I now need to buy a Manfrotto tripod or is there a way of attaching the two?
As you can see, I'm not well up on tripods and accessories
