08-02-2017, 06:23 AM   #16
Rectangular filters are almost essential for ND grads, but can have issues with dark ND filters due to light getting to the back of the filters through the filter mount.
I certainly prefer screw on filters for dark filters. If you're just wanting to experiment you could try shade 8 welding glass instead of a 10 stop. Its only a couple of bucks & will usually fit in a Cokin P holder (but can also be held in place by various DIY methods, such as gaffer tape, elastic bands, etc).
Color cast (severe green) & optical quality won't be great, but the results can still be impressive, after a little processing.
Welding glass strength is quoted in 'shades' which work out roughly:
Shade 8 = 10 Stops
Shade 9 = 11 Stops
Shade 10 = 12 Stops
Shade 13 = 17 Stops
Shade 14 = 18 Stops
08-02-2017, 07:00 PM   #17
QuoteOriginally posted by clickclick Quote
[snip] Also, Breakthrough Technology should be checked out, and I don't know the status of it, but they had a combination CPL and ND filter in the works, and I think they did sizing up to the 100mm range, so that would be something to check out too. I looked at them for the 15-30, but they didn't have anything that worked. Hope that changes at some point. [snip]
Need to update/correct my prior post. On further checking, Breakthrough Technology does have a 150mm square CPL, and that should work with the Fotodiox Wonderpana system I reference that fits the D FA 15-30.
08-04-2017, 03:12 PM   #18
I had another though, I already have a cpl for mr 21mm lens. Would adding the drop in holder on top cause vignetting?
08-05-2017, 06:33 AM   #19
QuoteOriginally posted by serothis Quote
It probably depends on the holder. Have you identified a system that fits your lens? What is the lens?
21mm, filter, filters, scenario, square, square vs, stack, tripod
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
"Recommended" variable ND vs "recommended" ND set madison_wi_gal Pentax Camera and Field Accessories 11 03-22-2017 12:19 AM
Handholding a ND square filter pixie Photographic Technique 17 09-02-2014 05:46 PM
For Sale - Sold: Galen Rowell Filter set** ND-2G-HS and ND-2G-SS** P size 84mm x 120mm davidgreen3003 Sold Items 2 12-30-2013 02:05 PM
Variable ND Filter - Fader ND mark II yusuf Pentax SLR Lens Discussion 2 11-16-2010 11:39 AM
All times are GMT -7. The time now is 09:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
