08-19-2017, 01:54 PM   #16
QuoteOriginally posted by savoche Quote
I must be the odd one out.
Yes. But I do exactly the same.
08-19-2017, 02:14 PM   #17
I've tried a few different straps but have ended up using the original. Never as a neck strap, though. Either over a shoulder or, more often, wrapped three times around my wrist. The wrist wrap makes for a snug fit that supports the camera nicely. Not suited for heavy lenses, but I've walked for hours with a K-3 and DA55-300.
Honestly I was okay with the K5 original strap and had never really thought about it (well, that 60-250 did make me think about it sometimes) but the lining (underside) deteriorated and began rubbing off on my clothes - leaving what looked like rubber treadmarks.
However I would never use anything as a shoulder strap alone - too easy for it to slip off. I do wrap the strap around my wrist sometimes, but not the entire strap, so this strap would work for that as well.
08-20-2017, 11:57 AM   #18
Seeker of Knowledge
aslyfox's Avatar
the nice thing about my set up:
Utility Sling - Neoprene Quick Release Camera Shoulder Strap | OP/TECH USA + joby Camera Hand Strap | Ultra Fit Hand Strap With Ultra Plate
is that I can quickly detach the sling with the clip and have only the hand strap on the camera.
likewise, I can use the hand strap to support the camera and lens while also using the strap
or I can let go of the hand grip and let the strap alone take the weight of the camera and lens.
" variety is the spice of life " someone said.
the only down side is that I must use an " Allen " hex wrench to release the ultra plate to change the battery in the camera body.
Since I use the camera grip, with its own battery, I usually don't have to mess with the battery in the camera body while in the field.
replacement, replacement neck, tripod
Neck strap or hand strap? Both JimmyDranox Accessory and Memory Articles 21 07-18-2021 02:31 PM
question about the strap lug "protector" volosong Pentax K-1 & K-1 II 8 05-06-2016 11:08 AM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
K7 Strap lug problem nakey Pentax DSLR Discussion 23 04-19-2010 06:03 PM
Spotmatic II loose strap lug question Steve Beswick Pentax Film SLR Discussion 4 11-20-2009 10:23 AM
All times are GMT -7. The time now is 12:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
