Originally posted by lats I can pick a pair of these up for $20 locally.
I'm using a K10d?
Useful, useless?
Should I just grab them?
What other equipment do I need to use them? i could quite understand the threads about the double cable release. Do I need that for digital?
Cheers
Andrew
The double release won't help you with your K10d, don't worry about it. A common single one may be convenient for viewing, but won't release the shutter.
If it's a screw-mount bellows, you'll want a K-mount adapter to connect it to your camera with, and also, if you have a grip on your K10d, that'll have to come off so it'll all fit up. A short macro extension tube (this can be either K or screwmount) will enable you to mount the camera without removing the grip, though the range of motion will still be limited.
Obviously, for a screwmount bellows, you'll also need a screwmount lens to go with.
If you don't have a genuine Pentax adapter already, (and don't want to shell out for one,) I suggest, among the cheap kinds, the sort with a broad flange that'll go between the lens mount and lens. (You'd lose infinity focus with a regular lens, using this, but in macro you'll never notice, and the cheap ones that try to fit just inside the lens mount aren't worth hassling with.
So happens Geauxpez gave me the very bellows mentioned in this thread.
20 dollars is certainly a good price, we can help you work out the rest no prob.
