08-23-2008, 07:01 AM   #1
geauxpez's Avatar
Asahi Pentax Auto Bellows - "Auto?"
I have an Asahi Pentax Auto Bellows for screwmount. What is so auto about it? In the brief time that I've played with it, it seems quite manual to me.
08-23-2008, 07:11 AM   #2
Banned
the 'Auto' refers to the diaphragm on the mount for open aperture metering on fully automatic diaphragm Takumar lenses (the later Takumars) it also refers to the same thing with the Auto bellows for K mount. I have an Auto bellows-M and love it very much, great fun and superb for macro with my smc-M 50mm 1.7
08-23-2008, 07:14 AM   #3
geauxpez's Avatar
So....does that mean that when the shutter is depressed the lens stops down then re-opens -- even with the bellows?
08-23-2008, 08:30 AM   #4
Wheatfield's Avatar
QuoteOriginally posted by geauxpez Quote
Essentially, there is nothing auto about it.
08-23-2008, 08:35 AM   #5
Ole
Ole's Avatar
You must use a cable release attached to the lens mount to close/open the diaphragm.
I the old days you used a double cable release, one end screwed into the camera, the other into the lens mount on the bellows unit. Hence "auto" - when you release the camera with the cable release, the lens would stop down and back up.
The DSLR's are not compatible with such a cable release.
08-23-2008, 10:40 AM   #6
geauxpez's Avatar
Ah. MAkes sense. I just got my m42-to-K adapter in the mail yesterday, so I'll play with it this weekend with my k10D. I just stop the lens down, spot meter & shoot. I took some test shots with a Spotmatic & 135/3.5 and was surpirsed that everything seemed to work well (all of that gear was previously untested).
08-23-2008, 11:29 AM   #7
ryan s's Avatar
The auto stopdown, unfortunately, doesn't work in the digital age. But it's good news if you still use screw mount film bodies.
I can't find my set though
08-25-2008, 08:09 AM   #8
Banned
I don't own the double cable release either not that its of any use now, but you can use a single cable release. it comes in handy with a tripod. you can quickly stop down the lens to check focus and DOF for adjustments and then stop it down and lock it, meter the light (or set it to Av once its locked) then depress the shutter. (as you can see in the photo) for hand holding you can use the shutter button on the bellows itself for the same thing and I find it rather easy to quickly stop it down for checks then rotate it slightly to lock it and meter the light. I don't know if the older m42 bellows have the same thing but I would assume so. I don't see why pentax doesn't make a camera with a shutter that allows for use of a mechanical cable release, it would be just as easy to implement with digital as it is for a film camera...
08-25-2008, 11:15 AM   #9
geauxpez's Avatar
Excellent -- thanks for the explanation & photo. I'll have to play with it.
08-27-2008, 01:33 PM   #10
Blue's Avatar
The diaphragm is.
Edit: Its ironic that I have the canon FD version of this with double cable release on my desk at work.
08-27-2008, 01:37 PM   #11
Otis Memorial Pentaxian
QuoteOriginally posted by séamuis Quote
I don't own the double cable release either...
OOOO...But you do own a K-mount auto-bellows! Very, very nice.
08-27-2008, 02:13 PM   #12
Do the the Auto Bellows actually allow full aperture metering? I thought they were simply compatible with Super Takumars and later in terms of the auto diaphragm. It looks to me based on various manuals that event the Bellows K required stop-down metering and did not maintain a linkage sufficient for open aperture metering.
Asahi Pentax MX Manual states "Use of other K Series accessories - standard Extension Tube Set K, Helicoid Extension Tube K, Auto-Bellows K and Bellows Unit K - requires stop-down metering. Whenever any one of these is used between the camera body and an SMC Pentax lens, the stopdown metering system must be used."
woof!
08-27-2008, 03:11 PM   #13
Blue's Avatar
QuoteOriginally posted by woof Quote
woof!
No. What happens is the double cable works in 2 stages. The first closes the aperture to the selected setting and then releases the shutter. This is true even for the Canon FD Auto bellows setup. I haven't used a Pentax K setup and can't specifically say much about it.
08-27-2008, 03:59 PM   #14
woof!
No, you don't get open-aperture metering. You do get open-aperture focusing!
08-27-2008, 07:06 PM   #15
Didn't think so... THIS confused me:
Probably just me. In truth, simply remove all references to open aperture as irrelevant, especially where Super Takumars are concerned. Make it...
>> the 'Auto' refers to the diaphragm... on fully automatic diaphragm Takumar
>> lenses
Thanks. Great thread. Probably saved me from doing something stupid like purchasing an auto bellows in mint condition... without the release cables. Heh.
woof!
asahi, asahi pentax auto, auto, pentax, tripod
What "AUTO" on a manual focus Vivitar lens? emr Pentax SLR Lens Discussion 5 08-06-2010 09:56 AM
Asahi Pentax Auto Bellows Jo Catherine Photographic Technique 3 09-15-2009 09:05 AM
For Sale - Sold: Asahi Pentax Auto Bellows M set séamuis Sold Items 15 06-12-2009 01:24 AM
The scene I'd been waiting for for a long time ("auto art" from street lighting) m8o Photo Critique 7 11-03-2008 09:24 PM
For Sale - Sold: Pentax SMC-M 50mm f2 & Sears "Auto" MC 28mm f2.8 inneyeseakay Sold Items 1 01-29-2007 12:23 PM
All times are GMT -7. The time now is 11:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
