11-01-2017, 01:19 AM   #16
Starting buying metal Japanese screw-on lens caps back in the '80s, and they're all I use.
Like the way they feel, look, and protect.
11-01-2017, 05:13 AM   #17
35mmfilmfan's Avatar
Just found this on eBay - any suitable ?
pentax pka lens cap | eBay
11-01-2017, 05:46 AM   #18
timw4mail's Avatar
My thought exactly. I'd rather have a plastic, clipped lens cap which can either shatter or jump out, taking some of the shock's energy with it along the way.
It's the same with modern cars : they're meant to absorb energy so you don't have to.
Somehow I doubt there's that much engineering to lens caps... just that plastic absorbs energy better than metal.
11-02-2017, 08:32 AM   #19
csa
csa's Avatar
I replaced my da 15 hood as soon as possible with a pinch cap. The speed of putting screw on caps on and off is either too much of a pain and the cap says off longer than normal, or an impediment to a quick shot, or both.
I agree, I do not like the screw on caps! I've gone to the lens Hood Hats from OpTech for most of my lenses, & prefer them to even the pinch caps.
Hood Hat - Lens Cover | OP/TECH USA
11-02-2017, 08:43 AM   #20
Senior Moderator
Parallax's Avatar
Wouldn't those screw-in caps be more likely to dent or damage the filter threads if impacted from the front?
It would make them less vulnerable as the impact force would be distributed over the entirety of the threads rather than a single point or small area.
You can demonstrate this by striking a bare bolt on the end with a hammer and look at the thread damage. Now try the same thing with another one with a nut screwed on covering the threads.
11-02-2017, 10:09 AM   #21
UncleVanya's Avatar
QuoteOriginally posted by Parallax Quote
That doesn't seem like a similar comparison. The lens threads area is a hollow section unlike the bolt. The problem Adam is talking likely has to do with the elastic vs. inelastic collision that may occur - how much the lens bounces off and how much energy is absorbed by the cap breaking or dislodging vs. how much energy is retained in the collision. I would think a metal screw in cap has a higher chance for an inelastic collision.
---------- Post added 11-02-17 at 01:10 PM ----------
QuoteOriginally posted by csa Quote
Do you see any wear on the lens where these contact them?
11-02-2017, 10:27 AM   #22
csa
csa's Avatar
No, no wear visible at all. These are a very soft material, so unlikely they would wear the finish on lenses.
11-02-2017, 11:18 AM   #23
UncleVanya's Avatar
Even fingers and bags wear lenses bodies over time - so I was worried. But good to hear that they do not appear to do so.
11-02-2017, 12:05 PM   #24
It would make them less vulnerable as the impact force would be distributed over the entirety of the threads rather than a single point or small area. You can demonstrate this by striking a bare bolt on the end with a hammer and look at the thread damage. Now try the same thing with another one with a nut screwed on covering the threads.
Yeah, what I'm thinking is if the cap gets hit and goes flying off (as would be the case with a plastic clip on cap), the force of the impact would be diverted away from the lens entirely as it bounces back from the collision.
11-02-2017, 03:02 PM - 2 Likes   #25
Digitalis's Avatar
11-02-2017, 03:06 PM   #26
UncleVanya's Avatar
Badges of honor.
11-02-2017, 04:14 PM   #27
csa
csa's Avatar
This is just my experience so far. I'm not a "heavy hitter" photographer taking hundreds of shots a day, etc. But so far I've not seen any wear on any of my lenses.
11-02-2017, 05:55 PM   #28
That's not my experience. Fortunately I had a UV screw-on filter that shattered but still protected the lens. I'm confident that if I had a metal screw on lens cap installed I would have suffered no damage. But I also kind of like the look and feel - not trying to convince anyone else - just interested in opinions.
11-03-2017, 12:02 AM   #29
Digitalis's Avatar
Badges of honor.
Unless sandpaper is involved, which is tragically the case with pre-aged Leica cameras.
My FA limited lenses are brassing up nicely. I don't mistreat my gear, but I don't coddle either.
11-03-2017, 05:49 AM   #30
UncleVanya's Avatar
WOW! What a tragedy.
bolt, cap, caps, collision, hood, lens, metal, screw, screw on lens, threads, tripod
Anywhere to get cheap rear caps and front caps? SenorBeef Pentax SLR Lens Discussion 39 07-17-2012 11:09 AM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
Pentax Body Caps and Rear Lens Caps aekn Pentax DSLR Discussion 18 10-14-2011 01:45 PM
Screw driven AF cameras. More high end = better screw drive? Reportage Pentax DSLR Discussion 13 09-01-2011 08:38 AM
I think I figured the screw-on caps... alexeyga Pentax SLR Lens Discussion 15 12-28-2010 11:43 AM
All times are GMT -7. The time now is 04:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
