11-02-2017, 12:01 PM   #1
pendennis's Avatar
Battery Tray For Pentax ME-II
I located and bought a Winder ME-II to use on my Super Program.
The winder arrived, but the battery tray wouldn't remain seated with batteries in it. Found a parts-only winder on eBay to get its tray ($1.00). It arrived today, and I tried the tray on my working winder. It won't seat, either. In fact, the end tab broke when I closed the tray into place. Batteries exert enough pressure to keep the tray from staying seated. I noticed that the end tab flexed a great deal on both trays, and it seems this is the issue. The tray from the winder on my Program Plus will remain seated. There doesn't appear to be a secondary seating lock.
I don't want to keep looking for winders with the same problem.
Has anyone else had this problem, and did you come up with a solution more permanent than the original?
Thanks.
11-02-2017, 02:05 PM   #2
pschlute's Avatar
I suggest a thick rubber band, and yes I am being serious
11-02-2017, 02:54 PM   #3
pendennis's Avatar
Thanks, and I can appreciate your solution.
This looks like a very bad design, exacerbated by the need to change out batteries. I have a couple of older Nikon drives MD-12's, and they're really built well.
I found a dead motor drive, so maybe I'll take it to a local repair shop, and see if they can revive it. It's a much sturdier design.
11-03-2017, 06:28 AM   #4
The plastic latch is the weak point on the MEII winder. It is difficult to find one that is not broken. I built a replacement out of a piece of brass stock that I cut down to size. It was somewhat successful, but ended up going the rubber ban route myself. I eventually got the motor drive A which is a lot heavier, but also has the extra controls for shooting vertically. Maybe use a three d printer to make a new latch?
Jim
batteries, battery, battery tray, program, tab, tray, tray for pentax, tripod, winder
My Q's Memory Card Tray Wont Lock vega Pentax Q 2 12-08-2015 11:26 AM
AA battery tray for Battery Grip BG-4 markf Pentax DSLR Discussion 12 07-23-2013 11:40 PM
Wanted - Acquired: AA battery tray for Battery Grip BG-4 markf Sold Items 4 07-20-2013 01:47 PM
Pentax 110 battery tray mdborai Film SLRs and Compact Film Cameras 2 01-20-2013 03:21 PM
Do you Do you use AA battery tray in your battery grip? LFLee Pentax K-5 & K-5 II 16 02-04-2012 11:23 PM
All times are GMT -7. The time now is 07:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
