Originally posted by Ontarian50 With vintage motor drives (and flash units), the number one cause of trouble is bad battery contacts.
Often the devices were stored with old leaking batteries in them for months or years. Cleaning the contacts thoroughly often helps, although it can be hard to reach the ones deep inside a motor drive battery compartment.
If the batteries leaked badly, then the corrosion spreads to surrounding wires and circuitry, making repairs much more difficult, if worthwhile at all.
Shine a light down inside the battery compartment, and maybe you can see the cause of your troubles. If all is pristine, then the problem is more serious.
The battery contacts have been inspected and thoroughly cleaned, even though there were no signs of battery leaks, or age-type corrosion. The positive and negative contacts in the battery trays are the actual battery contacts.
Thanks for the response.
