I've had various size Cokin (brand) adapter rings for decades, but for the first time the 77mm one bent recently. I store them the same way I always have, in the holders (I have one holder, in this case a since-filter holder, for each ring, so I don't have to move them between holders.) Has anybody else experienced this problem? I have found some instances in searching, but wondered if it's common, since it's never happened to me before. Has anyone successful fixed a bent ring? I fiddled with trying to bend it back but it has to be very precise and I could never get it flat enough for the threads to work again. Has anyone had better luck with any other brand of adapter ring? I imagine the problem would be even worse with an 82mm size.
