01-19-2018, 02:03 PM   #1
What tripod do you use for travel?
Hello,
I would like to ask for your recommendation of a good travel tripod. I have a cheap one which works, but it’s a bit unstable, and it’s not easy to tweak horizontal and vertical direction. I want to invest in a better one, but still retaining the compactness.
By compactness, I expect it to be less than 45mm, ideally even less when folding, because we travel a lot on cheap airlines, with hand baggage only. Weight is also important, but less so than size. I also wish that it is easy and fast to setup, and adjust.
With all that, if it could be less than 100$ it would be great.
Do you know any that matches?
Thank you very much.
01-19-2018, 02:19 PM   #2
This is one that I have: Sirui T-1005X 5-Section Aluminum Tripod SUT1005X B&H Photo Video
I also have a Sirui ball head. This the web address to it also in case you are interested: https://www.bhphotovideo.com/c/product/822261-REG/Sirui_BSRK20_K_20x_Ball_Head.html
There is also a carbon fiber version of the tripod I mentioned. It is the Sirui T-1205X.
These are the tripod specs:
Maximum Height of 51.4"
Load Capacity of 22 lbs
Forged Aluminum Chassis
Rapid/Reversible Center Column
Short Center Column for Low-Angle Shots
Folds Down to 13.4"
Weighs 2.2 lbs
01-19-2018, 02:24 PM   #3
Now some..
Rollei C5i + head T2S
So far works good
Got 2 camera Arca swiss plates
01-19-2018, 02:24 PM   #4
david94903's Avatar
I bought a used Sirui T-025X carbon fiber tripod, for $89 on sale through Hunts Camera. It's a great light weight tripod, fits into my carry-on bag, and it supports my K-1 comfortably.
01-19-2018, 02:45 PM   #5
Seeker of Knowledge
aslyfox's Avatar
here is a link to the section of the forums where members have reviewed tripods and tripod heads
Tripods - Pentax Camera Accessory Review Database
Tripod Heads - Pentax Camera Accessory Review Database
and monopods
Monopods - Pentax Camera Accessory Review Database
there is another option that might be useable, it is a brace which can be mounted to a monopod or just held against the shoulder:
Rifle Style Mount StediStock II reviews - Pentax Camera Accessory Review Database
01-19-2018, 03:12 PM - 1 Like   #6
Otis Memorial Pentaxian
Stable, compact/lightweight, affordable...Choose two...
A few years ago I did a couple of guest blog posts for Hin under the title "The Magic Tripod" that chronicled my search for an affordable lightweight tripod for under $100.
Hin's Photo Corner: The Magic Tripod
Hin's Photo Corner: Magic Tripod, Part II
I was pretty happy with the articles. They include most of what I might include here, so I suggest a click-through.
I have been pretty happy with my choice (Slik Pro 330DX legs with Manfrotto 494 head) in the seven years since those articles. The kit has been carried many miles strapped to my pack and has also gone on a few minor photo expeditions (Alaska, Yosemite, and New Mexico) where air travel was involved. My comments at this late date:
  • I am still a bit torn whether four-segment legs might travel better than the three-segment legs of the 330DX, though I don't intend to switch mine out
  • Even though I specifically sought a non-QR head design, I have since added a DAC-X1 Arca-Swiss skeleton-type clamp to allow easy use of my plate-equipped dSLR. It works great, weighs little, and goes on/off in a jiffy.
Oh...FWIW, I have no relation to Slik, Manfrotto, or DAX.
01-19-2018, 03:30 PM   #7
mhoule418's Avatar
M5 mini tripod
Hello
The M5 mini tripod may be good (or too small) for what you are looking for.
I don’t own one, but I have seen and manipulated one in a store.
Fotopro M5 Mini Tripod | eBay
01-19-2018, 03:48 PM   #8
Sirui T-005X. Aluminum tripod, $99 including ballhead. 31cm folded. Sirui T-005X Aluminum Tripod with C-10S Ball Head SUT005KX B&H
It is very compact when folded. It can fit inside many bags or hang outside. The carabiner can be hooked on the side of my belt for easy access during short walks; it swings a little but doesn't interfere with my gait.
It adequately supports my K-1 with 28-105 or 15-30. I rarely extend the center column because it can vibrate, so I get 124 cm height from the tripod. Use a remote, shutter timer, or phone app to trigger the camera.
Note that I have never brought it as carry-on baggage, only checked. Arbitrary TSA staff might fear it could be used as a bludgeon.
P.S. It's a travel tripod, emphasis on being small yet giving fair height. For significant long exposure or telephoto I use a larger tripod.
01-19-2018, 07:21 PM - 2 Likes   #9
Sandy Hancock's Avatar
I also have the Sirui - the carbon version. I could not recommend it highly enough; it's light, sturdy, full-featured, and more than capable of holding the K-1 and the very heavy DFA15-30 steady.
Or the FA31
It's even better suited to the KP and DA limiteds
01-19-2018, 07:37 PM   #10
QuoteOriginally posted by DeadJohn Quote
That has been my practice as well, though was surprised on a recent trip to see backpack carry-ons with fairly large tripods attached being carried on the concourse. This was in Alaska, so it may depend on the airport. The most amazing thing I have seen was on a recent long flight to North Carolina where a passenger carried a good-sized set of deer antlers that he held on his lap the entire way. I pity what might have happened to that guy with a rough landing.
01-19-2018, 07:40 PM   #11
ramseybuckeye's Avatar
I own two Mefoto travel tripods, the Backpacker and Daytrip, both fit easily in carry on bags. My Backpacker has a center column that is fixed in the up position, sturdy enough but keeps you from getting low. They have corrected that mistake in the newer versions. That Daytrip is a very small tripod, but very good. It was not perfect either because it had a "mini" arca type QR, I easily swapped that out for a regular size arca type QR. I only paid $50 for it but it is discontinued now. I use it as a table top tripod also, and it is great for hikes. I only bring it up because you may find one somewhere for a great price. That Sirui T-005X looks like a winner also.
01-20-2018, 01:52 AM   #12
I use Slik CF-614. Without the head when folded it is 48mm. 1.8lb. I unscrew the head and keep it separate. I have used it with DFA 70-200mm f2.8.
Cons are
-4 sections
-screw type joints.
01-20-2018, 02:27 AM   #13
This is a great question to ask. I too am contemplating and keen to see what others are thinking.
I am contemplating the Joby Gorilla 3K
GorillaPod 3K Kit - Professional-grade ABS flexible tripod with ball-head capable of holding 3kg of DSLR or Mirrorless Camera
simply because it is super light and versatile. It may also avoid being classed a weapon :/
I intend to use with a K-1, FA20, FA43 and FA77 with all camera equipment being carry on luggage.
01-20-2018, 04:51 AM   #14
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Wild Mark Quote
I wonder how that would actually do with a K 3+ battery grip + a D FA 150-450mm zoom
battery grip any idea of a weight on that?
800 + 2000 + ? = 2800+ g
98 ounces or 6 pounds and 3 ounces plus
3 kilograms = 6.9 pounds
01-20-2018, 04:59 AM   #15
QuoteOriginally posted by Aslyfox Quote
For that setup I would probably upgrade to the 5K (5 kg) - but even still I suspect you are pushing its limits.
To limit any vibrations I intend to use a remote trigger
travel, tripod
Your vehicle: what do you have, why do you like it, and what do you not like? Auzzie-Phoenix General Talk 2980 04-12-2024 05:06 PM
Do you use in-camera GPS for travel? ffking General Photography 13 08-08-2017 02:31 AM
when you travel how do you do it ? Erikka Travel, Events, and Groups 15 01-13-2017 08:58 AM
What do you think of this ebay-listed travel tripod? sholtzma Pentax Camera and Field Accessories 9 01-19-2015 11:12 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
All times are GMT -7. The time now is 03:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
