Originally posted by sqrrl
On the flipside of that - things like mount adapters are pretty hard to screw up (dimensionally speaking), so don't spend too much, the cheap metal mounts tend to be aluminium, which wears down quickly, but not so quickly that you won't be able to use it well enough to decide if you want to spend more on a better quality brass unit. I tend to buy very cheap to check things out and then pay more as needed.
I bought a cheap "Polaroid" branded T-mount adapter made in India. It was total crap. The lock set screws would not stay set, the finish rough enough you could use it as sand paper and the T-thread would not thread into any of my T-mount lenses and the K-mount had significant movement even when locked.
And then there are the cheap set of no-name M42 extension tubes I bought. They thread together fine. All my screw mount lenses thread into them fine. But none of the tubes will thread into any of my screwmount bodies, bellows or adapters (OEM or third party).
You can't play if the pieces don't fit.
