02-05-2018, 11:59 PM   #1
Seeking correct power cord for TR Power Pack-2
I just bought a TR Power Pack-2 to use this with my AF-540 flash unit.
The AF-540 manual says that it can't used with the Power Pack-2 for "mechanical reasons." However, some blogger says that the Power Pack 3 (which can be used with the AF-540) uses the same power connector as the Power Pack 2. Furthermore, they determined that the Power Pack 2 can, in fact, work with the AF-540.
My only questions are: what cord should I use and where might I find it.
I notice that the flash unit has a spot for a power connector as well as a five-pin connector. Could I use the five pin connector cord (example) as pictured in one of the attached photos to connect to the Power Pack 2 or would I have to use the power cord that's pictured in the Power Pack 2 instruction manual?
Thanks in advance for any and all advice.
02-06-2018, 02:07 AM   #2
I'd use the one that came with the flash. I have the TR pack III for the AF-540 FTZ and I've just checked and the cord also fits the AF-500 FTZ that the TR Pack II was designed for.
Regards
Chris
02-06-2018, 01:35 PM   #3
UncleVanya's Avatar
I'm pretty sure I used the TRII with my AF540 using the cord that came with the TRII but I cannot be certain.
Here's an article that seems to indicate no differences - note that he modified his unit to make it easier to use a longer cord. Also I have read many many times to avoid NiCads the low internal resistance allows them to pump too much current and melt (Literally) the unit. You would need to heavily modify the unit to permit high duty cycles by upgrading the wires and internal parts and then even the springs from what I recall reading.
Modifying Pentax TR Power Pack: Pentax SLR Talk Forum: Digital Photography Review
Here's another article that talks about the possible danger of melting the unit:
Pentax TR Power Pack & II & III, I'm surprised ... - PentaxForums.com
Best advice is use more flash units and perhaps pick up the JJC unit that uses AA's.
02-06-2018, 01:36 PM   #4
Read this:
Pentax TR Power Pack 2 Multilation
Note that the 5-pin port on the flash is NOT for external power supply.
02-06-2018, 01:42 PM   #5
UncleVanya's Avatar
As far as I recall the 5 pin connector is for sync. You can connect to a hot shoe adapter or a port that is compatible to get full P-TTL function off camera:
amazon.com : Pentax F5P 9.5-Foot Extension Cord for Pentax Flash Units : Camera Flashes : Camera & Photo?tag=pentaxforums-20&
It is NOT for power.
02-06-2018, 05:24 PM   #6
QuoteOriginally posted by seventhdr Quote
Regards
Chris
Thanks, Chris.
Do you happen to know what that cord is called? I can't seem to find it anywhere online.
---------- Post added 02-06-18 at 06:27 PM ----------
Thanks for that information. I don't think I'm set up to do those upgrades to the battery pack but I have no issue using alkaline batteries so I should be fine with this item if I can locate the darn plug.
02-06-2018, 06:53 PM   #7
QuoteOriginally posted by Nathaniel C Quote
Unfortunately, that cable was difficult to find as replacement part, even when the TR-2 and TR-3 were still in production. Now that they are discontinued, it's even more difficult.
02-06-2018, 10:14 PM   #8
QuoteOriginally posted by SOldBear Quote
Yikes! You gotta love proprietary cables...
af-540, article, cable, connector, cord, cord for tr, flash, ii, iii, pack, pack-2, pentax, power, power cable, power cord, tr, tr power pack-2, trii, tripod, unit
? on TR Power Pack III or TR Power Pack II pin-out and voltage SOldBear Pentax Camera and Field Accessories 1 11-16-2014 05:39 PM
For Sale - Sold: PENTAX TR Power Pack 3 battery pack for flash djrocks66 Sold Items 3 08-11-2013 08:11 AM
For Sale - Sold: two Pentax TR Power Pack-2 (external flash power) yurihuta Sold Items 2 03-13-2013 07:59 AM
Power cord for a TR Power Pack 2 Vern Pentax Camera and Field Accessories 4 12-06-2009 08:13 AM
All times are GMT -7. The time now is 05:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
