02-06-2018, 03:55 PM   #16
QuoteOriginally posted by csa Quote
That is exactly why I decided to add this fix to my outfit. Where I ran the leather thru the top of the connector, I feel is the strongest part of the connector itself.
Another weak point is where the eyelet is attached to the camera body. The leather piece in your set up does not address this issue.
02-06-2018, 03:56 PM   #17
Seeker of Knowledge
aslyfox's Avatar
Allen, I believe it could, but since it attaches to the strap, if there's a failure of the strap somewhere, it wouldn't help.
if the utility sling ( the portion across the body ] fails yes
if the quick connect holding camera body to the sling is the failure point however, not the sling itself then it would be the fail safe system
you understand what I am trying to describe??
the sling is around your chest, the camera is connected to the sling via the quick connect attached at the upper connection point, the tripod foot is connected separately to the sling via another separate quick connect
---------- Post added 02-06-18 at 16:56 ----------
QuoteOriginally posted by SOldBear Quote
there may be no perfect solution
02-06-2018, 04:03 PM   #18
QuoteOriginally posted by Aslyfox Quote
See the photo in my post above with "two point" attachment: the eyelet, and the tripod plate.
If one fails, there is still the other. Not perfect, but better then any "one point" attachment.
02-06-2018, 04:06 PM - 2 Likes   #19
PEG Moderator
Kerrowdown's Avatar
There's only so much weight a strap is designed to take
I couldn't agree more...
02-06-2018, 04:11 PM   #20
Seeker of Knowledge
aslyfox's Avatar
true
multiple back ups can be helpful
as I said, I have the Optech USA utility sling
Utility Strap?-Sling & Utility Strap?-Sling XL Quick Adjust - Neoprene Quick Release Camera Shoulder Strap | OP/TECH USA
attached to the right upper attachment point along with the joby hand strap with ultra plate
Camera Hand Strap | Ultra Fit Hand Strap With Ultra Plate
attached to the same point and the tripod screw plus the
Joby camera tether
Camera Safety tether for backup protection
attached to the other upper attachment point and the D ring free to hook onto the utility sling
now I am thinking about how to add a support for when I use long lenses attaching at the tripod foot
I think your set up is a viable set up as well
02-06-2018, 04:47 PM   #21
csa
csa's Avatar
We cannot possibly safeguard everything. I've never heard of the eyelet failing, I suppose it could, but I don't know how we can safeguard against that!
Of course, I could also take a fall, and destroy the camera & lens; can't really do anything about that either.
I just thought I'd share this idea with those that are interested.
02-06-2018, 04:49 PM   #22
csa
csa's Avatar
I'm not using the sling, however.
02-06-2018, 04:54 PM - 1 Like   #23
Seeker of Knowledge
aslyfox's Avatar
. . . I just thought I'd share this idea with those that are interested.
I think your sharing is a great idea
02-06-2018, 04:55 PM   #24
I've never heard of the eyelet failing....
Happened to my Fujica years ago; the camera fell 4 ft onto concrete.
I vowed never allowing that to happen again....
02-06-2018, 05:00 PM   #25
csa
csa's Avatar
So, what is your solution? I would have to run additional straps from a new tripod plate (as mine only has an access place on one side), up to each side of the strap. By this time, with all the additional straps, it would be a mess trying to get it on/off the tripod.
02-06-2018, 05:01 PM   #26
csa
csa's Avatar
Thanks Allen! We can't possibly be prepared for every catastrophe that might happen, but try to prevent what we can.
02-06-2018, 06:01 PM   #27
I disagree. First defence: hold tight. Second defence: strap round neck. Third and final defence: Good insurance.
02-06-2018, 06:02 PM   #28
I make my own straps with black 1/2 inch polyester utility strap (same width as original Pentax strap). That way I can have the strap length I need. I have never had a strength problem.
02-06-2018, 06:04 PM - 1 Like   #29
Seeker of Knowledge
aslyfox's Avatar
. . . We can't possibly be prepared for every catastrophe that might happen, but try to prevent what we can.
QuoteOriginally posted by victormeldrew Quote
everyone is entitled to their own opinion
I am a firm believer in
Murphy's Law:
Any thing that can go wrong will go wrong
and
Finnegan's corollary to Murphy's Law
Murphy was an optimist
YMMV
( nothing wrong with good insurance )
02-06-2018, 06:07 PM   #30
BigMackCam's Avatar
Even insurance policies have limitations, and don't always pay out. But I agree that it's another excellent thing to have where practical and relevant. In the UK, I have specific cover through Aaduki, on top of my home insurance. Covers most situations... but not everything...
body, camera, failure, leather, safety, sling, strap, tripod
Streets Health & Safety issue photomax7 Post Your Photos! 2 01-15-2018 12:40 AM
"Kodak Safety Film" ancient bulk load, but it seems ok! gdneil Film Processing, Scanning, and Darkroom 13 12-17-2016 04:37 AM
Black & White Extra safety TroutHunterJohn Post Your Photos! 6 12-13-2016 10:07 PM
Safety first... gdneil Monthly Photo Contests 2 07-12-2016 10:00 AM
Safety: Pixco hand grip and Sun Sniper shoulder strap Zafar Iqbal Pentax Camera and Field Accessories 11 10-26-2011 12:03 AM
All times are GMT -7. The time now is 01:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
