Originally posted by csa Allen, I believe it could, but since it attaches to the strap, if there's a failure of the strap somewhere, it wouldn't help.
if the utility sling ( the portion across the body ] fails yes
if the quick connect holding camera body to the sling is the failure point however, not the sling itself then it would be the fail safe system
you understand what I am trying to describe??
the sling is around your chest, the camera is connected to the sling via the quick connect attached at the upper connection point, the tripod foot is connected separately to the sling via another separate quick connect
---------- Post added 02-06-18 at 16:56 ----------
Originally posted by SOldBear Another weak point is where the eyelet is attached to the camera body. The leather piece in your set up does not address this issue.
there may be no perfect solution
