No doubt the TC's added 'glass' will have
some measurable effect on
comparitive image quality. I accept that and choose not to evaluate the use of a TC
solely on the basis of absolute IQ alone.
I consider a TC to be something that changes the
geometry of the scene -- the perspective lines/vanishing points -- rather than simply a 'magnifier'. It changes where I may (or have to?) stand to frame a given scene as I want...the edge of a cliff, a blind, a river bank, in flight...whenever unable to "zoom with your feet" or swap out lens FLs.
Changes in practicable exposure values when using a TC will also affect (may degrade, or sometimes even enhance?) 'bokeh', shutter-speed, DoF, etc.
Unfortunately CSA's shots didn't include enough background to make my points -- perhaps this comparison will serve to illustrate my concept - shot with different FL effect aside from magnification -- although this was shot primarily to maintain subject size:
Some personal thoughts: A TC will...
- have many different effects through out the FL range of a zoom lens.
- change the shooting location / perspective points of any scene
- possibly be the only way to frame a scene from a given or desired position
- best be used ONLY with the BEST lens
at hand to frame the scene as desired (I had an Adaptall SP 180 mm plus Pz-AF 1.4x TC that outperformed any other equivalent lens option available to me between 150 - 300 mm - I do miss it!
- until I acquired the DA*300. So, you may ask, do I shoot the 300 with a TC? Yes, when the situation warrants it for best effect.)
I look for the best
overall result rather than simply the arguably best IQ after PP even if that comes with a slight degradation in absolute comparative IQ. If I'm pleased with the final result why measurebate over an alternate choice-not-made?
