03-13-2018, 10:12 AM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by Ronald Oakes Quote
Its load rating is OK though.
Both tripod and head load ratings are traditionally highly overstated and even in best case assume a well-balanced load. For my regular tripod setup, I am over-spec'ed about 2x for both head and head and legs and still wish at times that I had a little more robust head.
03-13-2018, 12:48 PM   #17
UncleVanya's Avatar
To add to this. There does not appear to be a measurement standard either. So while I typically follow the same path as Steve (1/2 the rating being my max load) I think this is more of a starting place as the construction and results of the combination of legs and head are pretty easy to judge in person. The wide variation in what a head design/size is rated at is not uncommon with the more reputable manufacturers being more conservative.
03-13-2018, 12:56 PM   #18
The rated max load is 12kg. So half is 6kg x 2.2lbs = 13.2lbs
I'm ok with this as my entire setup is less than half that. I will be able to tell as soon as I get it in my hands.
300mm, 300mm f4 lens, f4, head, k-mount, lens, pentax lens, slr lens, takumar, takumar 300mm f4, tripod, tripod head
Need help figuring out tripod and tripod head for k3 II Infinite Ascension Troubleshooting and Beginner Help 32 03-27-2018 07:05 PM
Video Head (tripod head) Question... littledrawe Pentax Camera and Field Accessories 3 04-23-2012 12:14 AM
Tripod Head - Can I add Rotation to my current ball head claimed4all Pentax Camera and Field Accessories 5 10-11-2011 09:34 AM
Gear head vs. 3-way pan tripod head heatherslightbox Pentax Camera and Field Accessories 3 05-22-2009 06:54 PM
All times are GMT -7. The time now is 11:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
