Originally posted by stevebrot Nikon K3*, while not as sensitive to display of out-of-focus at wide apertures as the S-type screens, is equivalent to that used on the Ec-B
I know K3 has very good reputation, and that was one of the first screens I tried.
I have K3 screen installed on K5II, Ec-B on K5, and Ee-S on K30 and k10D. Ec-B is better in only showing the in-focus area "in focus", particularly for fast lens.
Steve, I have an off topic question here, since you know screen very well: Have you heard a focus screen does not work with 1.2 lens? I have two screens, Ee-S and Ec-B, both were very carefully calibrated and shimmed to ensure accurate focus. I have no issue with 35/1.4, 50/1.4 and 85/1.4 lenses. But, my K50/1.2 focuses a lot closer, although in the VF, it looks perfect. If I calibrate the screen using K50 1.2, my other lenses are off. I don't have a 2nd K mount 1.2 lens to test.
My other camera has a cheap eBay split screen does not have this problem. The one I took from Minolta camera also works fine.
Any thoughts?
