Originally posted by Clem Nichols I'm considering the purchase of a new tripod, and some of the Bogen Manfrotto models with the center column that rotates 90 degrees to a horizontal position are on my short list.
I finally bought a heavy tripod and went with a cross bar type. I looked at the Manfrotto models but decided on the
Induro AX-214.
Part of the reason for going with the Induro model was the center column has a lot more horizontal adjustment than the Manfrotto models. The Manfrotto models only do 90 degrees, the Induro can do a full 180 degree sweep. The other part was Amazon had the AX-214 for US $149,. The usual street price is US $186. It was down to US $129 at one point, and I'm kicking myself for not getting it then.
With the legs fully extended, the center post collapsed, and the camera on a 3 3/4 inch tall ball head and QR system, the top of the QR base is at 62 inches. Add another 3 inch of camera below the viewfinder and the height of the view finder with center column collapsed is around 65 inches or about 5 foot 5 inches.
The tripod comes with a shoulder strap and bag, both are pretty nice quality wise. The Shoulder strap can be used with or without the bag to carry the tripod. It also comes with a small tool pouch, again nicely made, that has a nut wrench, an Allen wrench, and three spiked feet for the legs.
The tripod is a bit heavy, I bought the aluminum version, so it is to be expected. The tripod is rated for 17 lbs. The ball head I'm using is rated for 22 pounds. I think this will work out for a while.
I didn't answer your question about if the horizontal ability being a gimmick because I just haven't used the tripod enough to know. I prefer to have the option versus not having it, as I can't see any issue in having it available, except the added weight. A year or two from now, I might be able to answer, but for now it is just something I want in a tripod versus need to have.
Thank you
Russell
