03-30-2018, 10:15 PM - 1 Like   #16
QuoteOriginally posted by Cipher Quote
I've had good luck with my MeFOTO RoadTrip A1350Q1R
Cheap ($150), Compact (4x4x15" in a case), light, reasonably stiff when weighted down.
It wouldn't hold your 645z with the 400mm but should work with the smaller lenses.
It takes Arca-Swiss plates, one leg detaches to form a monopod. Its height range is 17" to 61".
If you don't mind Orange and no monopod, the older model is available for $82:
Thanks Cipher. I will check out items suggested by you.
---------- Post added 03-30-18 at 10:17 PM ----------
QuoteOriginally posted by rdenney Quote
Look at the Tiltall carbon fiber tripod legs, which B&H sell for $289.
Tiltall Tripod TC-224 Carbon Fiber Tripod TC-224 B&H Photo Video
These are reasonably stiff and of decent quality. With a four-section leg, it should gold up pretty small, and it only weighs 2 pounds for the legs. You also unscrew one leg and use it as a monopod.
Then, choose any three-way pan-tilt head, which will be stiff per dollar than ball heads. Not as compact, but there are good choices well under $100. Don't get a cheap ball-head.
The ThinkTank bag I pictured was about $130 or something like that, but it's certainly not the least expensive alternative, nor is it the most.
Rick "don't extend the center column in use" Denney
Thanks Denney. I guess items suggested by you make a lot of sense. If necessary, I shall try and increase my budget. Thank you all for your kind suggestions.
---------- Post added 03-30-18 at 10:43 PM ----------
Thanks you everyone. I wonder why my replies aren't getting posted. Hope this one works. Thank you all.
03-31-2018, 05:39 AM   #17
UncleVanya's Avatar
QuoteOriginally posted by leonine Quote
This one worked.
03-31-2018, 12:33 PM   #18
It indeed did :-)
645z, advise, bag, camera, camera bag, combination, exposure, fiber, gitzo, head, kit, leg, legs, lens, luggage, monopod, night, pentax, range, shots, tiltall, travel tripod, tripod, tripod and camera
What's Your Favorite Camera Bag That Looks Nothing Like a Camera Bag? reivax Pentax Camera and Field Accessories 19 10-19-2017 07:09 PM
Travel kit: have I got it right? Sandy Hancock Travel, Events, and Groups 63 06-23-2017 11:19 AM
High Speed Sync on the 645z with EL Quadra's, working, kind of. psenior1 Pentax Medium Format 4 11-26-2016 08:41 AM
Small bag options for 645z and travel 2351HD Pentax Medium Format 13 03-27-2016 02:47 AM
Modifying folding chair bag into tripod bag Chris Stearns Pentax Camera and Field Accessories 10 07-03-2009 07:34 AM
All times are GMT -7. The time now is 12:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
