03-23-2018, 11:05 AM   #1
Track Sliders
Recently I invested in a track slider. Something I thought would have great utility in many applications. Like every time you are using a tripod.
There are many brands to choose from at different price levels many well under $100US. After a quick comparison I went with the VidPro 24" Professional Track Slider & Skater Dolly Combo. It was $90US. All the brands look to be made from the same types of materials as the VidPro. It was exactly what I was hoping. The materials are solid. Every thing comes apart in particular the VidPro Skater Dolly wheels can be taken off. Even the end legs can be removed to just have the rail attached to a tripod.
Where a rail comes in handy is giving some leeway to moving the camera without having to move the tripod entirely. Close Macro work in studio or in the field greatly benefits from a track slider. Like in the yard capturing all those Spring flowers coming around the corner in the Northern Hemisphere. Then of course all those other things that really benefit from the use of a track slider like stitching images together with great precision. Even in a bird stand shooting through a window a track slider gives some left to right movement for greater angle of view.
Being aluminum the VidPro is fairly light. Light enough it is worth taking to save on time not having to reposition your tripod as much.
I think it was well worth the $90US. I don't see how the wives could object. Anyone else using one?
03-23-2018, 06:02 PM   #2
QuoteOriginally posted by Rico Quote
Track Sliders
Same but Different : Rails for Macro, Product & Portraiture etc. No dolly's. Few years back I bought 12 " & 6 " 2 Way rails from the Orient and put them together for a 12 " - 4 Way for my heavy Manfroto and 6 " - 4 way for my lighter and more portable Velbon with ball head. They are both mounted on common release plates so can be used on anything I have. (mono pod ,table pod, window pod) They are very sturdy and can handle the weight of K3 + grip + Sigma Bigma. They have screw adjuster knobs and locking knobs. I have put common release plates on all my Cameras and long lenses incl some point & shooters. There are lots of male and female 1/4 screw mounts on both sizes and the 12" rails have 4 flash hot shoe receivers. I believe back in the day the hole kit & cabootle cost me about $100 USD. I brought it in the house one piece at a time and it suddenly showed up as if it had been there forever.
03-24-2018, 11:00 AM   #3
pacerr's Avatar
Sliders/racks can be quite useful for many purposes.
Here's one of a few I've cobbled together from old, cannibalized bellows. Disassemble, modify and re-assemble parts in whatever configuration needed. The lens mount bracket(s) have been removed (hacksaw) and the camera mount flipped in this example. Two racks may be stacked at 90-degrees for additional flexibility. A bubble level affixed to the frame (glued?) may be useful as well.
Many cheap re-badged, third party bellows used common parts making mix-and-match projects easy.
03-25-2018, 06:33 AM   #4
TaoMaas's Avatar
I've got a Rig Rat slider that I use for video. I'd never thought about using it for still photography. I also have a macro focusing rail so I'd always used that when needed. Using my slider is a good idea though. It offers a lot more movement. Thanks!
03-31-2018, 03:01 PM   #5
QuoteOriginally posted by pacerr Quote
OK ! What I really want to know is...on the second image , what /where is that base ? Aluminum ? Easily obtainable ?
04-03-2018, 03:49 PM   #6
pacerr's Avatar
QuoteOriginally posted by Ronald Oakes Quote
Check PMs - 3/31/18 -
Aluminum 'hat-section' extrusion available at local metal supply / recycling shops
04-04-2018, 03:17 PM   #7
QuoteOriginally posted by honey bo bo Quote
My apologies honey bo bo for seemingly in not including the ladies as the husbands have a lot to learn from the wives.
Thanks for the feedback everyone. One of those $20 6" adjustment plates will really complete what I need.
honey bo bo you may be able to transition in a track slider by just adding your rig on top as if it were always set up like that.
brands, light, materials, rail, skater, slider, time, track, tripod
People Sliders bossa Pentax K-3 Photo Contest 25 06-04-2014 03:53 AM
Does Konova regularly update their sliders? iNicole Troubleshooting and Beginner Help 0 01-21-2013 10:07 PM
Abstract When sliders go wild ! daacon Post Your Photos! 8 09-19-2011 06:43 AM
Three Presence Sliders in Lightroom 2 mithrandir Digital Processing, Software, and Printing 5 02-24-2009 05:13 PM
All times are GMT -7. The time now is 08:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
