Originally posted by C_Jones I have a Bogen Manfrotto tripod, but instead of using it for shooting, I decided to purchase two Sirui tripods. They are easy to store and the way they work with my Sirui ballhead is great. The tripods and ballhead use the arca swiss plate/head mount. Just in case you decide you may be interested in the tripods or the ballhead, shortcuts to them are below. The T-1005X is the lighter and more compact of the two tripods, but is also very well built.
I have a warning about the Siruir ball heads.
4 months into owning the middle model I had the baseplate become separated from the main body of the ball head out in the field while attaching my D800 and 50mm 1.8, Thankfully I was still holding onto the camera while this happened.
Getting back to the house I found that 3 tiny screws stripped out and where pulled out of the body
I have taken off the quick release clamp to be used on another ball head so ignore that its missing
Here you can see the holes where the screws are pulled out, for me these tiny screws are way to small for what I would consider as a safe way of securing the base to the main body and especially for their recommended weight this ball head is rated for.
For the record this head was mainly used for landscape and was not abused.
If you want to see how small the screws are for yourself you can turn the base plate while the head is not attached to the tripod and thru the access hole you can look down to see the size of the screw.
