04-11-2018, 03:53 PM   #1
Sound when turning filter thread
Recently I purchased a UV & Haze filter. I put it on Sigma 180mm macro. When I turn the filter it makes rather loud noise. Filter is not tight, it went in smoothly but made rather loud noise. Its makes similar sound during unscrewing. Will this damage the thread of lens? Should I return the filter?
04-11-2018, 04:01 PM   #2
Check that the filter threads on the lens and filter do not have dirt in them or burrs (where the filter thread has been unevenly cut).
Try them on another lens if you can.
Regards
Chris
04-11-2018, 04:11 PM   #3
BigMackCam's Avatar
Is the noise you're hearing a loud "squeaking" or "scraping" sound? If it's a "squeaking" sound, this is quite normal with many filters and lenses, and not something to worry about unduly. If it's a "scraping" sound, it could be that there are bits of abrasive material on the threads of the filter or lens, or that the threads of the filter are badly cut. Try cleaning those threads with a lightly-moistened cotton bud to see if that helps.
So long as the filter attaches and removes from the lens without much effort, there's very little chance of either being damaged. If you have to put some strength into it, though, there's a problem - most likely with the filter, since most lenses are very consistent in the threading.
04-11-2018, 04:36 PM   #4
As @seventhdr noted it is BURR sound. I do not have any other lens of size 72mm. But I have couple of 72mm filters, and none of them make that sound.
I will clean the thread using alcohol and then try.
04-11-2018, 05:40 PM   #5
ramseybuckeye's Avatar
It could even be some uneven paint grinding off. If you find a burr you may be able to knock it off with a knife or small file.
04-11-2018, 06:14 PM - 1 Like   #6
Toothbrush
I like a stiff bristle toothbrush for getting to the bottom of threads. Toothbrush wont damage threads and does a good job. First make sure its very clean.
04-11-2018, 10:07 PM   #7
I wiped using alcohol and that did not help. I will try with tooth brush. Great idea
04-17-2018, 05:05 AM   #8
Common problem, simply dry threads. Apply a very tiny amount of Vaseline to the filter thread, screw it onto the lens then remove it and wipe off any excess from the filter and the lens thread. Enough lubricant will remain at the bottom of the threads to prevent the noise and make fitting and removal much easier.
04-17-2018, 10:30 AM   #9
After cleaning with tooth brush sound reduced substantially. Thanks for the Vaseline idea, i will try.
04-17-2018, 11:29 AM   #10
BigMackCam's Avatar
QuoteOriginally posted by pentaxfall Quote
Another good option that I've used before is to take a reasonably soft pencil (a 2B or similar), and "draw" along the outer edge and inner surface of the filter thread in question. It provides enough lubrication to stop jamming of stacked filters, so it might work for your noisy filter too
filter, noise, sound, thread, tripod
FA 77 limited - increasing friction turning focussing ring? wartaler Pentax SLR Lens Discussion 2 10-29-2017 11:49 PM
K1 - GPS not turning on/off properly and camera power-on sporadic clickclick Troubleshooting and Beginner Help 4 07-09-2017 07:12 PM
Lens focus at end, motor keeps turning Tighelander Non-Pentax: Canon, Nikon, Sony, etc. 2 06-09-2016 09:41 PM
K-5 Sound when turning on camera/focus issue? mcook Troubleshooting and Beginner Help 9 07-18-2012 11:25 PM
Error turning off thread subscription emails Williunck Site Suggestions and Help 2 07-02-2012 07:15 PM
All times are GMT -7. The time now is 11:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
