Originally posted by macman24054 If you are using off camera then I love my Octabox. They give a circular catch light, assemble in just a couple minutes (most of the time is to put on the front panel diffuser) and give a nice soft light. I have a 32" and 47" version. They are the umbrella type and you can find them on Amazon for a really good price. The light mounts inside so you need a cold shoe bracket with an umbrella holder (also cheap on Amazon). Since getting them I rarely use an umbrella or my 55" Octabox with the base plate and rods (real pain to put together and take apart).
If you have time, please have a look for those parts and specific Octabox on b&h's site as I am putting a large order in and they ship to Australia. Amazon can be hit or miss when it comes to shipping this way (and normally more expensive shipping). Thanks for the suggestions, if you don't have time don't worry I'll have a hunt myself, but there seems to be a lot of 'Octabox's' so was just curious to know the exact model you have and stand by.
Originally posted by Paul the Sunman Good suggestion. I actually watched a video comparing the flashbender with an array of different diffusers one of which is a Gary Fong diffuser (which I own), so it feels that the flashbender is probably too similar to that device (which is what I have to rely on currently), but thanks for the suggestion!
Originally posted by C_Jones If interested in a 24 x 24 that comes with an S bracket (Bowens) for speedlight, the below is listed at B and H. The difference in this one from the RAYA one is that the top of the flash is held by a clamp type bracket instead of the foot of the flash being in a cold shoe mount, which allows for less of a chance of the flash foot being affected/damaged. The bracket can also utilize umbrellas. The softbox itself has a four cornered set of sides which pull over the bracket for mounting instead of accepting a rotating mount. I have never used one, but it seems like an inexpensive alternative that you get a bracket with.
Godox S-Type Bowens Mount Flash Bracket with Softbox SFUV6060 Yeh I saw that one also, cheers.
Originally posted by pentaxfall Softbox that I linked can wrap around fixture of any size because at the rear end, 4 sides of softbox are not
stitched instead they use velcro. It is like joining 4 petals using velcro. Light may leak but small amount. Velcro makes softbox adaptable to different fixtures.
Watch 5.05min
How to Set Up Softbox Lighting Kit (Fancierstudio) - YouTube Yep I see, interesting.
Originally posted by RAART In the field I am using this:
8080-octagon-SOFTBOX-grid
I tried with softboxes different sizes but it did not work for me... The thing is that you will find very soon that the power of one flash is not sufficient unless you working with big battery powered studio lights, therefore I had to think what I can do to avoid hauling big heavy lights with me. The solution that I was coming with is to combine multiple flash lights into one softbox and that I linked above worked perfectly. I just added this -->
Triple Hot Shoe Light and Sound Bracket with Umbrella Holder, Mount J and mounted 3 flashes around. I am using Yongnuo YN560 TX controller and a mix of 560IV and 560III flashes.
The good thing is that I can also pack few umbrellas with me (I have one very, very large umbrella) and can change in very short time from brolly box to shoot through umbrella for very soft light. I group usually all 3 flashes in one group and change power level on all of them at same time but also can shut down one flash if needed. It is very effective and portable setup. and fits all in one bag (Tall light stand + flashes + umbrellas and batteries). Also I have with me one small light stand that I use with another flash light that I control also with same controller for back lightning if necessary.
Have fun finding the right combo. It is winding road to discovery...
That's why you're here
I think you are the future me, in that if I go down the softbox route I will be throwing money away and eventually come round to your conclusion. Of all the suggestions I like this one the most. I will already be carrying a bag or sling bag of some description that is orientated to pack in long cylindrical objects such as lightstands and tripods, so if the softbox is actually compressing down to being an umbrella design (rather than something that is a bit more cumbersome to pack away like a weird shaped tent) then that makes life simpler from a setup, pack away and carrying perspective. Then I can also (due to the size and space) add additional flash power also (if need be).
I'm a little lost on the passage highlighted bold, are you saying that the setup can also take an umbrella placed in front to further diffuse the flash light?
Thanks for the links, once again I am putting an order in at b&h so if you are able to find exactly what you use on that site (or something you think of as the equivalent then please by all means be my guest
If not I will try looking and link you back perhaps.
Thanks everyone for your help!
