05-26-2018, 12:24 AM   #1
Chetverovod's Avatar
What flash can I use for auto and manual lenses?
Hello, some days ago I had feel strong desire to bought a flash. What model will be best if I want to use autofocus lenses and manual (M42) lenses?
05-26-2018, 08:45 AM - 1 Like   #2
mcgregni's Avatar
Autofocus lenses can be used with any flash mode, but old manual lenses cannot be used with P-TTL (automatic exposure) flash mode. So as long as your flash has both P-TTL and Manual flash modes you can do everything needed.
The old "Auto Thyristor" flash mode is also good with manual lenses, providing automatic flash exposures but without needing aperture and other info transmitted from the camera. The older Pentax AF-360 / 540 FGZ flashes provide all three modes I've mentioned. Some older Metz models may also. Otherwise buy a newer P-TTL / M flash and also an old Thyristor type from the film days. Auto-Thyristor mode is labour intensive in terms of settings and flash exposure control however, as you need to juggle aperture and ISO inputs on both flash and camera, as well as perhaps needing to read off distance or aperture figures depending on the model and it's era.
05-26-2018, 08:56 AM   #3
Thank you, Nigel! I had read your flash guide 2015, and selected AF540FGZ. Thank you for detailed guides.
Best regards!
05-26-2018, 09:03 AM   #4
mcgregni's Avatar
Good choice of flash ! There's a section in my Guide about the A mode and how to control flash exposure using it.
06-04-2018, 12:45 PM   #5
Lowell Goudge's Avatar
QuoteOriginally posted by Chetverovod Quote
it is really dependent on the body as well as the lenses
for legacy lenses i use my *istD as it can run in TTL and P-TTL mode, if there is no A setting the camera automatically sets to TTL, it an A contact is sensed, it shoots P-TTL.
i am not sure how many of the *istD range run both flash modes, but clearly by the K series TTL was gone
06-05-2018, 08:34 AM   #6
Hello, Lowell Goudge,
I have a choise between Q, K-01 and K-5 all of them a later than *istD.
Thank you.
06-05-2018, 06:57 PM   #7
If you are limited to a more modern camera then you need a flash that shoots in auto mode with an internal light sensor, for a relatively high power unit , again the AF 540 FTZ can work in this mode, you would need to enter shooting aperture into the flash, and shoot in manual mode below 1/125. I recommend this because the flash duration can lead to some trailing curtain cut off of the exposure at maximum power and maximum sync speed
06-05-2018, 09:29 PM   #8
Thank you for for important information, it will save my time and nervous health during first attempts of using flash and manual lenses. I think in this week i will get a parcel with flash and start practice.
flash, lenses, tripod
Manual lens - is auto ISO possible with manual shutter speed ? madbrain Pentax K-1 & K-1 II 10 05-08-2018 07:16 AM
Do you use only manual focus lenses?Do a lot of folks use only manual lenses? heralu Pentax DSLR Discussion 12 01-05-2011 04:06 PM
Can I use old manual lenses on new K-m DSLR? falamslam Troubleshooting and Beginner Help 3 12-15-2009 04:22 PM
Can the K2000, K200D, or K20D use all pentax manual lenses? Abstractational Troubleshooting and Beginner Help 20 09-15-2009 09:50 PM
For Sale - Sold: Multiple Auto (Digital & Film) and Manual Lenses, flash + more jjdgti Sold Items 18 10-03-2008 09:30 AM
All times are GMT -7. The time now is 10:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
