05-27-2018, 11:01 AM   #1
Jome's Avatar
Flash for Macro under 150$?
Hello dear Pentaxians,
I would like to try macro pictures (Flowers, insects, product detail,...) with my K-3, some macro rings, the 35mm ltd macro and A-lenses but I am limited by a light problem: light itself.
I have seen macro flash with LED or other lamps. What would be the best course of action (it has to be portable)
I have seen the AF 160FC but it is far too expensive for me
Could You please advice?
Kind regards.
J.
05-27-2018, 11:12 AM   #2
swanlefitte's Avatar
There are many solutions. Be sure to check out this thread for some ideas.
Our macro rigs - PentaxForums.com
05-27-2018, 11:22 AM   #3
UncleVanya's Avatar
LESTER DINE SUNPAK MACRO RING FLASH AD-27A PHOTO FLASH / AC ADAPTER | eBay
Should work in manual mode.
05-27-2018, 11:50 AM   #4
Jome's Avatar
QuoteOriginally posted by swanlefitte Quote
Wow, That was fast!
Thanks Swanlefitte
05-27-2018, 11:57 AM   #5
Jome's Avatar
Thanks for your fast advice UncleVanya.
05-27-2018, 12:17 PM   #6
Jome's Avatar
I have seen these so far with availability and prices from my location (including Taxes and shipping):
env 100$ (taxes and shipping hurts on that one) Lester Dine sunpack AS 27A, (looks like good old quality, Thanks UncleVanya)
env 75$ Andoer 550D with 48 LED (seems low quality)
env 140$ SIGMA EM 140 DG for pentax. (The Sigma is well quoted on the database, worth it for that price?)
I am still open to advices...
Kind Regards.
J.
05-27-2018, 01:32 PM   #7
Not a Number's Avatar
The old Sunpak GX/DX 8R is a popular choice and usually found well under $80 USD. With luck you can even find it with a Pentax (non-TTL) module or find the module separately. Manual down to 1/16th power or use the auto-sensor on the flash. After using it you very quickly get a feel for what apertures to use depending on subject and distance. The Pentax module will set the shutter speed for you.
Here's another budget setup using off-the-shelf mostly no-name equipment
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/242666-my-un...cro-flash.html
05-27-2018, 02:45 PM   #8
I can recommend Voking 'real' macro flash. 'Real' means it is actual flash, not LED lamp. It is well built and works with Pentax without any problems, albeit only in manual mode. If I remember correctly I paid around 100$ for new unit.
05-27-2018, 03:34 PM   #9
AggieDad's Avatar
For my macro setup I use 2 Amazon Basics Flashes ($28 ea) and a wireless trigger set - Neewer has one that is pretty cheap. The flashes can be set for power and the wireless allows me to put them where I want them without fighting wires. The whole package works a treat and you are cooking for less than $100.
Don
05-27-2018, 05:47 PM   #10
Custom User Title
FozzFoster's Avatar
I had the same issue recently.
I went for the Promaster RL 100. Very happy with the results !
RL100 LED Macro Ring Light
05-27-2018, 08:15 PM - 2 Likes   #11
Thagomizer's Avatar
Here's a different idea that might work, too. I've had great success (if I do say so myself) with an extender/diffuser on my K-S2's pop-up flash. The one I usually use is built using a couple of potato chip tins. It's cheap, light and probably more compact than anything else that you could add to your camera, which might let you get your camera into spaces a bigger flash rig might not fit into. I've even used a modified Starbuck's paper coffee cup for the same purpose, when I forgot my chip-tin version.
Here's my impromptu Starbucks extender/diffuser:
Here are shots I took using it with my Sigma 70mm:
The 70mm Sigma I used for the above images is my most commonly used lens when I'm shooting 1:1. I often shoot smaller insects at higher magnifications, hand held, with shorter working distance, using reversed lenses. The chip-tin extender might not be as useful a solution for subjects at greater distances than I'm usually shooting at. Whatever flash you end up using, adding diffusion will make a big difference to the quality of light and the quality of your images.
06-01-2018, 09:40 PM   #12
Jome's Avatar
Thanks You all for advices and samples!
With all your inputs, I can now narrow my criterias (for now):
- It will be a ring flash
- the lightest as possible (for also handled use) - also as the price of the shipping in correlated to the weight.
- not with LEDs
- able to be used in p-ttl mode if needed (Automatic And Manual)
- less than 150$ (second hands OK)
So, is the Sigma EM 140 DG PA-PTTL a good choice (I found one in my area, shipping included for 137 $)?
Kind regards.
J.
06-01-2018, 10:26 PM   #13
QuoteOriginally posted by Thagomizer Quote
I really like this idea. Thanks for showing this
06-02-2018, 06:44 AM - 1 Like   #14
Thagomizer's Avatar
QuoteOriginally posted by pentaxfall Quote
You're welcome!
The Pringles tin version can be made in sections so it telescopes to accomodate differing lens lengths. Cutting one section open lengthwise along one side allows you to add a spacer that permits the now larger diameter section to fit over the original diameter tube so it can slide back and forth.
06-22-2018, 05:35 AM - 1 Like   #15
+1
It looks like this:
flash, flash for macro, light, macro, tripod
DFA 150-450 vs Sigma 150-500 gerax Pentax SLR Lens Discussion 26 05-21-2018 09:24 PM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 16 02-17-2018 05:55 PM
Simple lens shootout Pentax HD DFA 150-450 vs Canon 100-400 II vs Sigma 150-600 C beholder3 Pentax SLR Lens Discussion 46 07-25-2016 12:33 AM
Macro for under 150$? Earth Eater Pentax SLR Lens Discussion 43 10-30-2010 08:29 AM
Why does Pentax consistently UNDER-EXPOSE and usually under-saturate images? PentaxForums-User Pentax DSLR Discussion 122 07-12-2010 06:14 AM
All times are GMT -7. The time now is 11:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
