07-20-2019, 12:05 PM   #46
A couple of you have mentioned the Bahtinov mask for use in photographing stars. Here's an stl code for a 150mm mask which can be easily resized in Cura when generating the gcode file for printing. A png is included showing the mask. The mask will also work if 2D printed on clear media (not translucent) making a film version which can be placed in front of a lens. The stl will result in a flat (2mm thick) mask which may need a retainer rim to hold it for a given lens. If sized properly, it will fit in a filter ring (use a spare UV or Haze filter).
Thanks to arach101 for putting me on to Fusion360 which was used to generate the mask. Fusion360 is free if you go through all the registration process and declare yourself an educational or hobby user, but it's not the smartest program on the block in some ways and is a bear to use offline because it takes so long to boot (not fast booting on line either). It is however, a very useful and feature filled 3D modeling program which converts generated models to stl format easily. Those can then be used directly in Cura to create the gcode files for many 3D printers.
03-01-2020, 09:13 AM   #47
I printed this K-mount to telescope eyepiece adapter a few months ago. I did a bit of testing and it works, although the resulting photos are just okay. Which I should probably expect using my kid's $50 400mm equivalent telescope.
PENTAX K-30  Photo
PENTAX K-30  Photo
05-08-2021, 05:29 AM - 5 Likes   #48
angerdan's Avatar
List of collected Pentax related 3D printable goodies
List of collected Pentax related 3D printable goodies:
  1. Pentax 31mm 1.8 Cokin P Filter adapter: Pentax 31mm 1.8 Cokin P filter adapter by Arachnorchis - Thingiverse
  2. Pentax/Tamron 15-30mm 150mm filter adapter: Tamron - Pentax 15-30mm 2.8 150mm Filter adapter by Arachnorchis - Thingiverse
  3. Cokin P filter holder: Cokin P 84mm 100mm and 150mm filter holder by Arachnorchis - Thingiverse
  4. Magnetic filter mount: Magnetic 100mm and 150mm filter mount adapter by Arachnorchis - Thingiverse
  5. USB charger for Pentax D-Li90 batteries: Camera Battery Phone Charger by walter - Thingiverse
  6. NATO/Picatinny Rail for Hot Shoe by Bikecyclist - Thingiverse
  7. Flash Hot Shoe Picatinny Rail (2 Slots) (5VS74B67J) by cynosurex
  8. D-LI90 battery contact cover (like with the old D-LI50 batteries): www.shinyrover.com/shinyrover/?p=1304
  9. Q Lens focus Lock utility: 03 Lens: Focus lock helper - PentaxForums.com
  10. Project to modify battery chargers for Panasonic batteries to fit Pentax D-LI90 (idea later used by somebody): Hähnel PROCUBE2 - 3D printed adapter for Pentax D-Li90 - PentaxForums.com
  11. Pentax D-Li90 battery cap by pentaglut - Thingiverse
  12. Pentax K-r DSLR Battery Pack Cover by donutman_2000 - Thingiverse
  13. Pentax MX Grip: 3DPrinting a MX Grip - PentaxForums.com
  14. K-mount to telescope eyepiece adapter: Pentax K-mount SLR to 1.25" telescope eyepiece adapter by xzivr - Thingiverse
  15. Pentax 645 Battery Holder - PentaxForums.com
  16. Tripod mount foot for F* 250-600mm by StigVidar: Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
05-08-2021, 09:55 AM   #49
Amazing things to make. This is a very useful compilation. Thanks or the work you put into making this list.
Thanks,
barondla
12-10-2021, 04:22 AM - 1 Like   #50
angerdan's Avatar
Addition:
16. Pentax 560mm lens foot
QuoteOriginally posted by Toolmaker Quote
...what I ended up doing is design a replacement foot for the lens to lower it that 1 1/2" and move the center of the foot to the balance center of the lens with a K-3 mounted to the lens. Whew! That was long winded.
I have the prototype ordered and if that works out I'm curious as to how many others see the need for a replacement foot.
I have an OLD Takamar 500mm lens and what my new 560 foot does (will do) is bring the lens center down to the height of the 500mm. I have added a picture of my design. Please don't steal it.
scroll down the quote to seee the drawing
12-17-2021, 08:44 PM - 3 Likes   #51
Arjay Bee's Avatar
Another addition which I will put up on Thingiverse - Pentax K1000 grip. If the base plates are the same as the KM or KX or K2 it will fit those as well. Given the weight of the camera I thought that it would be useful to have a bit more skin contact so this grip fits the palm and the outer three fingers. I used ABS filament and a higher resolution print setting so there is no flexing but still very light.
(If you download you will need to redrill the tripod hole. The simple program I was using left vestigial infill as the design process developed.)
07-07-2023, 06:02 AM   #52
angerdan's Avatar
I found this little gadget on STLFinder. Only uses the standard battery so you don't get more run time but still could be handy.
External Camera Battery Adapter - STLFinder
External Camera Battery Adapter by walter - Thingiverse
Parts for connecting a Pentax D-Li90 battery through the external power adapter of a K-3, K-5, K-5II, K-5IIs, or K-7.
Uses a Digikey H10485-N HiRose 3-Pos Low Profile connector.
100mm, 150mm, 31mm, 3d, adapter, batteries, budget, charger, cokin, filter, pentax, phone, pla, print, printer, stuff, tripod, walter
3D printable grips for LX and 6x7 simonpw Pentax Camera and Field Accessories 17 04-05-2019 03:20 PM
Adorama Secret Wednesday Sale *Printable Coupon* Adam Pentax Price Watch 5 11-12-2014 06:06 PM
Printable Version of Lens Reviews? jcamero Pentax SLR Lens Discussion 3 07-08-2012 02:14 PM
Cheap 3D - Sony Bloggie, Fuji W3, LG Optimus, HTC Evo 3D... or? Unsinkable II Canon, Nikon, Sony, and Other Camera Brands 7 06-23-2012 09:36 PM
Printable calendar software. callagh11 Digital Processing, Software, and Printing 4 11-12-2011 07:07 AM
All times are GMT -7. The time now is 01:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
