06-18-2018, 12:04 PM   #1
Jome's Avatar
quality step up rings?
Hello dear Pentaxian,
I would like to know where I can find step-up rings from 49 mm to anything that are VERY solid?
Thank You to let me know.
Kind regards.
J.
06-18-2018, 12:26 PM   #2
Digitiser of Film
BigMackCam's Avatar
Early last year I bought a set of step-up and step-down rings by K&F Concept (see my original post HERE). They're solid, the threads are well cut and finished, and I've been very happy with them so far. Much better than any other rings I've owned
06-18-2018, 12:33 PM   #3
Alex645's Avatar
QuoteOriginally posted by Jome Quote
What is your definition of "solid"?
Step up rings are made of either polycarbonate (the most likely to cross-thread or break), anodized aluminum (the most common), and brass (the most durable and considered the most 'reliable').
Both Heliopan and Sensei make brass step up rings, but in the 49mm+ sizes, you're looking at mostly Heliopan.
I prefer using BHphotovideo because of their selection, competitive prices, and it's easy to filter the parameters of what I need on the side bars of their web pages.
06-18-2018, 01:00 PM - 1 Like   #4
Otis Memorial Pentaxian
That is another way of asking what you are wanting to do that requires a robust ring.
06-18-2018, 01:04 PM   #5
SSGGeezer's Avatar
LOL! I was wondering myself since unless you are stacking them to act as a hood, how much stress does the average step up ring need to withstand?
06-18-2018, 01:26 PM   #6
Jome's Avatar
thanks!
Thanks!
Thanks! (BHphotovideo is quite expensive for me because I am living in Europe)
QuoteOriginally posted by SSGGeezer Quote
It is for a 55mm (or a 52mm) sigma ring flash...
06-18-2018, 01:31 PM   #7
SSGGeezer's Avatar
Go for the brass or well made aluminum models since that is a bit more weight than a filter. Probably not a huge amount but well machined threads are nice to spread the load bearing area around the lens.
06-18-2018, 01:35 PM   #8
Digitiser of Film
BigMackCam's Avatar
thanks!
The K&F Concepts rings are aluminium but very strong, with no "flex" like the awful generic / unbranded types . They'll work well for your ring flash, I'm sure.
06-18-2018, 01:49 PM   #9
Ohhhh...I would like one of those.
It is a real shame that adapters for 49mm are not included with most ring flash. I agree that a brass adapter would be desirable since it is often a pain to thread the flash onto the lens.
06-18-2018, 02:04 PM - 1 Like   #10
Jome's Avatar
I would not see the ring go away and smash on/to the ground
Thanks, seems that they are sold in packages (could be useful also with my 67mm lenses)
It will come probably tomorrow with 55mm, 58mm and 72mm ring flash adapter, it is a second hand Sigma EM 140 DG for Pentax (pttl, Yeah!)
06-18-2018, 02:14 PM   #11
Jome's Avatar
Hi Mike,
Is it those?
amazon.com : Step Up Ring, K&F Concept 22pcs Filter Ring Set 11pcs Step Down Adpater Ring + 11pcs Step Up Rings for Filters 52-55MM 55-58MM 72-77MM 77-82MM 58-55MM 62-58MM 67-62MM 72-67MM 77-72MM : Camera & Photo?tag=pentaxforums-20&
Thanks.
J.
06-18-2018, 02:14 PM   #12
Digitiser of Film
BigMackCam's Avatar
You're welcome
Honestly, the sets are so inexpensive that it's worth the small outlay to have multiple sizes on hand, just in case... especially since they can be stacked, so (within reason) it's possible to step up and down between most common sizes.
Good luck with your ring flash! Let us know how you get on?
06-18-2018, 02:15 PM   #13
I bought fotodiox rings, and they seem sturdy to me. Haven't used them a whole lot yet, but it's made out of metal and they have a quality feel to them.
06-18-2018, 02:26 PM   #14
Jome's Avatar
You're welcome
There is free shipping for order bigger than 25$, I thing I will go for it
For the flash, I will need to find some tutorial on that specific model and then...My learning curve will be for Macro and portrait And probably some LBA aftermath
06-18-2018, 02:28 PM   #15
Jome's Avatar
QuoteOriginally posted by awscreo Quote
Thanks Awscreo, did You tested it with a ring flash?
quality step, tripod
Good, inexpensive CPL filter and step-up / step-down rings BigMackCam Pentax SLR Lens Discussion 15 10-31-2019 05:46 AM
Disadvantages of moving filter away from front element? Step up/down rings G.E.Zekai General Photography 6 07-17-2017 01:52 PM
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
step-up or step-down rings? ncrecordkeeper Pentax Camera and Field Accessories 8 05-13-2010 07:31 AM
All times are GMT -7. The time now is 04:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
