Originally posted by SimonAtkinson I stopped using grad nd's a good while ago, with modern software and camera sensors, especially the K1's I either take one exposure, exposing for the highlights and lifting the shadows in post or I simply bracket a few exposures and combine in post. I personally think grad nd's are just an aging piece of equipment clinging onto the modern era.
I did wonder. I mean I have read that a cpl cannot be replicated in post, but I think that refers more to the reflection side of things rather than the 'bluer skies and deeper saturation/contrast'. I just took a panorama on the weekend with one stuck on my 24mm, and got that lovely bell shaped effect from the use of the cpl with 3 stitched images. It did make me wonder if I should dump the cpl for those shots and instead use a grad nd or nothing at all (hence this post).
The grad nd isn't just an expense however, it's another item to ferry around, and another item to mess about with/set up time, it will slow down the shooting on the day, however it make speed post processing up, so I guess it's a case of where do you like to waste time more, at home or in the field.
Sally... I mean Sandy!, I'd be keen to hear your feedback on your system once you've had a chance to play with it, please keep in touch
