07-02-2018, 02:05 PM   #1
Does an 8mm (less than 10mm) extension tube exist for Pentax?
I was hoping to find a 8mm or 10mm extension tube for wide angle experimentation with my 10mm Rokinon. Am I on a wild goose chase? Does anyone have other ideas short of purchasing another lens?
Thanks for your thoughts
Bob
07-02-2018, 02:26 PM   #2
Topsy's Avatar
With the mount being ~5mm deep (lens side) it'll probably be hard to find one. But I suppose if it's just for experimentation and not daily use you could try 3d printing one?
07-02-2018, 02:31 PM   #3
photoptimist's Avatar
How about sacrificing a rear lens cap and a body cap. A bit of sawing and epoxy could hack it together.
07-02-2018, 04:16 PM - 1 Like   #4
Not a Number's Avatar
The Nikon to K-mount adapters are around 8mm. You can buy them without glass elements. There are also glass-less K-mount lens to Nikon mount adapters available. Buy one of each and maybe you can swap the Pentax female bayonet from the Pentax to Nikon adapter onto Nikon to Pentax adapter (male Pentax bayonet).
Pentax Lens to Nikon Mount Adapter Ring Without Optical Glass/Macro D5300 D610 6943413701437 | eBay
Macro Adapter for Nikon F AI Lens to Pentax K mount PK camera K200D K-5 r 01 50 | eBay
The position of the locking tab might be a problem.
07-02-2018, 04:55 PM   #5
swanlefitte's Avatar
My extension kit has 3 tubes and the part that connects to the lens and the part that connects to the camera. I scewed just these together to use my 10-20mm. with no tube just the connections its 11mm +
You could probably get a camera cap and cut out the center with fins.
07-02-2018, 06:46 PM   #6
twilhelm's Avatar
I believe Ronald Oaks was looking for one a couple of months ago. If I remember right, he found either a 9mm or 10mm. It might be worth shooting him a pm to see where he found it.
07-02-2018, 09:26 PM   #7
What a cool idea. So far, all the rear lens caps I have are ~10mm thick, so adding the body cap will add some length too. Hmm. Maybe I can find a thinner rear cap - or cut one so it's a bit thinner. Hmm. Might be hard to make such a thin cut... Maybe there's a way to use a lens reversal ring as part of the rig..?
Thanks for the suggestion.
07-03-2018, 01:48 AM   #8
QuoteOriginally posted by twilhelm Quote
10mm M42
I need to find a 10mm M42 extension tube - PentaxForums.com
If you can find the Pentax made Extension Tube K (non-auto) the smallest tube is 9.5mm. The auto version is 12mm.
These claim the smallest tube is 7mm. But does that count the male and female adapter?
https://www.ebay.com/itm/Manual-Macro-Lens-Extension-Tube-Ring-for-Pentax-PK....c100005.m1851
07-03-2018, 08:29 PM   #9
10mm M42
Manual Macro Lens Extension Tube Ring for Pentax PK K Mount K-5 K-7 K200D K100D | eBay
For $7.19 I decided to give the ebay tubes a try. The 7mm tube, if it works, is really close to what I was after. I'm looking for closer-focusing than the lens alone, not necessarily 1:1. My internet search skill and endurance are *not* legendary. Without your help I never would have found these, thanks for your suggestion - and everyone else too!
This forum is Great!
07-27-2018, 10:53 AM   #10
Just an update: The $7.19 eBay simple extension tubes arrived from China - I had hoped that using only the male and female adapters alone would produce an extension of less than 10mm. Sadly, that is not the case. With these simple tubes, the smallest ring alone is 7mm - including the front/back adapters produces an extension of ~19mm. Screwing only the two adapters together produces 12mm, which is the same as the smallest of my Pentax Auto Extension tubes.
So in a sense, my $7.19 experiment was a failure...
More optimistically, I just succeeded in eliminating this particular option for wide-angle close focusing.
For now, I'll continue experimenting with my SMC A 28mm with the 12mm auto extension tube.
Thanks everyone for your input!
Bob
---------- Post added 07-27-18 at 11:59 AM ----------
For others interested, here are some options for wide angle macro. I am trying to avoid another lens purchase.
10mm, 12mm, 8mm, adapters, angle, auto, extension, lens, macro, tripod, tube, tubes
I need to find a 10mm M42 extension tube Ronald Oakes Pentax Camera and Field Accessories 5 03-20-2018 09:17 PM
Wanted - Acquired: M42 10mm extension tube Ronald Oakes Sold Items 4 03-20-2018 06:49 PM
Tripod load ratings at less than max extension? CreationBear Pentax Camera and Field Accessories 14 03-19-2017 02:53 PM
Sigma 8-16, Pentax Bodies & FL less than 10mm interested_observer Pentax SLR Lens Discussion 7 12-07-2013 09:34 AM
Does a less expensive alternative to the DA 15mm exist? mmrempen Pentax SLR Lens Discussion 31 09-21-2011 10:01 AM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
