10-02-2018, 02:46 PM   #1
FarmerJim's Avatar
Small travel bag for K-5 with O-GPS attached
Quick bag question...
I have a good travel bag that fits my K-5 with a 18-135 lens attached. There is room for one additional lens and also some accessories. It cannot accept the K-5 with the O-GPS1 attached however...
Any suggestions on a smallish travel bag (for a minimal travel kit) that will hold the K-5 with both a lens and the GPS unit attached?
Thanks for any advice/experience!
Jim
10-02-2018, 04:01 PM   #2
I would not bag a K-5 or any other DSLR with anything attached to the hotshoe. Too much leverage, too much chance of breakage. But that is just me.
10-02-2018, 04:04 PM   #3
@jbinpg Agree.
10-02-2018, 04:28 PM   #4
ramseybuckeye's Avatar
I would not bag it with that attached either, too easy to bend your hotshoe or break the GPS.
10-02-2018, 07:05 PM   #5
QuoteOriginally posted by jbinpg Quote
QuoteOriginally posted by pakinjapan Quote
@jbinpg Agree.
QuoteOriginally posted by ramseybuckeye Quote
I'm with these guys also. Don't risk it.
10-02-2018, 08:21 PM   #6
I like the Lowepro Toploader bags. I have the Toploader Zoom 50 AW and it fits a K5 with the 18-135 or the 16-85 with the hood reversed. The K5 will fit with the O-GPS attached, but like the other posters, I would not recommend keeping it attached because it is a tight fit. Not much room for an extra lens.
I also have the Toploader Pro 70 AW which fits the K5 with a bit more room for the O-GPS. The Pro 70 has room for a K5 with the grip or the K1. It does have room for a 2nd lens if it isn’t too long. You can also strap on a separate lends holder on the side, but it does get bulky at that point.
10-03-2018, 03:08 AM   #7
rogerstg's Avatar
+++ There've been many camera repairs needed due to simply bumping an attached flash. The hotshoe area of most cameras is pretty weak.
10-03-2018, 05:22 AM   #8
bdery's Avatar
Indeed. Just remove the GPS unit before inserting, it takes a few seconds after all.
If you MUST do it, then make sure the camera is snug, the lens held in place by a lower divider hugging it, no lateral movement possible, etc.
10-03-2018, 08:01 AM   #9
FarmerJim's Avatar
I am aware of the potential stress issues with storing the camera with the GPS unit attached.
The reason I was asking about a bag was to see if anyone knew of a bag where the risk is minimized due to the (thoughtful) design of the bag. If there is a bag designed to protect the camera +GPS, I would consider it. If there isn't, then I won't be doing it.
Thanks for the feedback.
10-03-2018, 08:44 AM   #10
geedee's Avatar
I am using my K-70 wito O-GPS in a Crumpler Cupcake 4000 bag. No problems whatsoever. The O-GPS is quite small and light and the bag is spacious an well padded so I don't see huge risks there. The bag apparently is discontinued, but perhaps you can find a similar model?
bag, bag for k-5, k-5, k-5 with o-gps, lens, travel, travel bag, tripod
Do you use in-camera GPS for travel? ffking General Photography 13 08-08-2017 02:31 AM
For Sale - Sold: Pentax GPS Unit O-GPS1 Hotshoe Mounted Accessory GPS Unit for Pentax Toolmaker Sold Items 3 10-08-2016 05:15 AM
Small bag options for 645z and travel 2351HD Pentax Medium Format 13 03-27-2016 02:47 AM
Small bag for k-x w/55-300mm attached chung_chang Troubleshooting and Beginner Help 20 03-23-2011 05:37 PM
Good small travel bag? jmbower Pentax Camera and Field Accessories 16 09-06-2007 03:39 PM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
