After over a year of being on the fence, I've finally bought into the Arca-Swiss quick-release system. I've acquired an Arca-Swiss Monoball Z1+ sp and a couple of plates, including a SpiderPro lens collar plate for use on my D FA* 70-200mm lens. I'm using this on my Oben CTM-2500 monopod, but will eventually get a better monopod
as well as a proper tripod, (
edit: see post #6) not to mention more lenses. Alas, my budget is limited and I don't have that much money to acquire all that gear at once.
The free motion allowed by a ball head takes some time to get used to, but the advantage of the Arca-Swiss head is that doesn't tip over as easily under load because it uses a spheroid ball whose tension increases as you move it away from the center position, addressing a problem I've constantly had with the tilt head it replaced.
The hard part, however, is properly deciding what heads and plates to buy. The Arca-Swiss QR system is very confusing to a newcomer, and I talked with the B&H sales associate for a long time before buying, discussing how supposedly "Arca-compatible" plates and mounts can be incompatible with other manufacturer's due to proprietary extensions and modifications, such as pins or other protrusions in the head and/or plate and inconsistent plate widths.
One last thing: B&H only lists the
Monoball Z1 sp but the new Z1+ sp has the same SKU, so don't be alarmed if you can't find the new Z1+ model on their website.
Any hints on using this or suggestions on future expansion? Your thoughts on the Arca-Swiss system and its compatibility issues?
Draco
