10-25-2018, 10:05 PM   #1
jhaji's Avatar
Can someone identify this Pentax ballhead clamp thingie? For 67?
Ball-joint on both ends. I know you know.
DSLR-A200  Photo
DSLR-A200  Photo
10-26-2018, 12:34 AM   #2
Not a Number's Avatar
What does it say below "PENTAX"? What does it say on the round part?
10-26-2018, 03:16 AM   #3
tvdtvdtvd's Avatar
Looks like a boom clamp of some sort. Perhaps from the medical division?
10-26-2018, 05:33 AM   #4
WPRESTO's Avatar
From the orientation of "Pentax" on the rectangular piece, it is designed to be clamped on the edge of something with the rounded section up. It looks as though the rounded section has holes for screws or bolts to hold something atop, perhaps for display.
10-26-2018, 06:59 AM   #5
Otis Memorial Pentaxian
What does it say on the base and below "Pentax" on the clamp? It appears there is a model name on the base.
As with the comment above, it is likely this goes with a medical device with the base being fixed to a counter top.
10-26-2018, 08:16 AM   #6
tvdtvdtvd's Avatar
QuoteOriginally posted by WPRESTO Quote
Or perhaps ceiling mounted, clamped to an articulated armature with a scope thingy at the end.
10-26-2018, 08:51 AM   #7
kayakfari's Avatar
This looks like a ram mount style holder and not a genuine Pentax product. Maybe to hold a phone?
10-26-2018, 09:53 AM   #8
jhaji's Avatar
PATLNTLD
Under the mount end, it says R-A-M. Has a figure of a ram which is trademarked. And it also says Pat. Pend.
The round end is a tripod mount which screws into DSLR threads. Quite sure this is an original Pentax part & probably for 67 since I got these in a lot with 67 accs.
DSLR-A200  Photo
10-26-2018, 09:56 AM   #9
I'd say something to do with lab equipment, the clamp looks like a lab clamp, normally clipped onto thin metal poles like this one:
Possibly holding a camera to take photos of experiments?
10-26-2018, 10:06 AM   #10
mikeSF's Avatar
i use something like this to mount a flash (or small strobe) to a stand.
could be similar
https://www.ebay.com/i/253933558730?chn=ps
10-26-2018, 10:26 AM   #11
jhaji's Avatar
It 6 1/2"(16.5 cm) long & weighs just over 10oz (290g). It is cast metal. Looks like aluminum on the portions with paint loss.
The lack of ball joints with feet at the end of the clamping screws suggests that this is a (semi-)permanent setup.
10-26-2018, 01:24 PM   #12
WPRESTO's Avatar
I suspect it's a simple table-top clamp. Clamp to edge of the table, the "PENTAX" is then upright, camera goes on the 1/4 X 20 screw, and you can alter the angle as with a ball dead.
10-26-2018, 05:15 PM   #13
Alex645's Avatar
It appears to be a pole clamp for a mini printer:
RAM Mount Pentax PocketJet Printer Clamp Tele-Pole Mount
10-26-2018, 06:03 PM - 2 Likes   #14
It's for mounting on an instrument panel glare shield in anr aircraft or car side door window edge. Made for Pentax by Ram Mounts Seattle, WA. Note the "patlntld" lettering on the glare shield mount under R-A-M.
RAMŽ Ball Adapter with Round Plate and 1/4"-20 Threaded Stud Unpackaged
RAMŽ Composite Double Socket Arm Unpackaged
RAMŽ Glare Shield Clamp Ball Base Unpackaged
11-30-2018, 05:53 PM - 2 Likes   #15
If you haven't played around with RAM gear yet it's time! Many major manufacturers now offer RAM products...Garmin, several boat manufacturers, CanAm ATV's etc. Very functional with ball sizes up to 2" for really heavy items. I use 'em for my heavy sonar/GPS units in my boat and sometimes for camera gear and flash set ups.
The RAM story is a great "guy makes good on idea" story. I met the developer/owner of RAM at his first public showing--the Seattle Boat Show about 20 years ago. The product was called Round-A-Mount which over the years was shortened to RAM. If you start looking at the full line-up, it seems there's nothing under 25 pounds that can't be RAM'ed. Better build quality than any of the other copycats I've ever played with.
ballhead, pentax ballhead, tripod
Nature An Interesting Thingie troika Post Your Photos! 4 03-01-2018 04:51 PM
Macro Just another Thistle thingie. eaglem Post Your Photos! 6 07-29-2012 07:57 AM
Can someone identify this pentax 50mm lens please? darthpotato94 Pentax SLR Lens Discussion 6 04-29-2012 05:47 PM
Can someone identify these M42 Hanimex lens? clockwork247 Pentax SLR Lens Discussion 3 04-13-2011 11:41 PM
Can someone identify this bird? Heinrich Lohmann Post Your Photos! 12 07-26-2008 10:43 PM
All times are GMT -7. The time now is 10:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
