12-23-2018, 05:46 AM - 1 Like   #16
I would reckon your tripod is fine for lenses up to a couple of kilos or so. The strength ratings of tripods for me are pretty meaningless - it's all about rigidity and how its being used. Any issue with your soligor 450mm will be due to its length, not weight, its not that heavy - what I refer to as bendy ruler syndrome, an inherent tendency for a long thin object to wobble and vibrate. You should check out some of the u-tube videos discussing things like weighting the tripod.
I customise plates for long lenses (this pic here shows the use of a cheap macro rail on the heavy and way out of balance tamron 200-500mm) so I can get them balanced - counters sag and wobble. However one counter point is that shutter/mirror related vibrations are best militated against by mounting the tripod at the camera - locks the camera down. If you suspect camera related vibrations then you can get tricky with two tripod or tripod + monopod set ups, dampening with sand bags etc
12-23-2018, 06:38 AM   #17
QuoteOriginally posted by marcusBMG Quote
Morning, Marcus!
The tendency to wobbly also applying to the third extension on the tripod - hence, the greater stability of using only two.
The biggest disadvantage to any tripod is my height - I invariably have to lean over to use them.
So, if I understand you, and my feeling, correctly, this tripod will likely work well with a good head on it. And, if the base isn't suitable, I can likely use the head on another base.
12-23-2018, 01:14 PM - 1 Like   #18
If you're not too worried about portability, a good choice is the Davis and Sanford Provista tripod with an FM18 fluid head. It's meant for videography with heavier cameras, and is very stable. The fluid head allows for controlled motion, or if you decide to go with a tracking mount like the Star Adventurer, you can remove the head and put that on instead(this is what I have).
12-23-2018, 01:59 PM   #19
QuoteOriginally posted by SteveinSLC Quote
I've seen Davis and Sanford and wondered about them. I take it they're better known in the video world?
---------- Post added 12-23-18 at 01:59 PM ----------
Also, the Star Adventurer kit looks like a fantastic piece of equipment. Does it also align and find based on GPS?[COLOR="Silver"]
12-23-2018, 05:24 PM - 1 Like   #20
Unless you're tracking, the only thing that matters with the tripod (other than the fact it safely can hold your camera and lens) is vibration once the shutter is tripped. Even a wimpy tripod can work since it's just positioning your shot and once any vibration dies out, you're in business. Of course, when the shutter trips, a sturdy tripod may offer less vibration than the wimpy one. Using a remote to trip the shutter is a must since touching the camera/lens will introduce shake that takes some time to die out and you can knock it off the subject if you attempt to press the shutter button with your finger.
Once you have your subject centered just don't touch the camera or tripod and use a remote to trip the shutter - see if that works for you.
12-23-2018, 05:51 PM   #21
QuoteOriginally posted by Bob 256 Quote
Bob,
I usually use a 12s timer for my moon shots. I've also programmed one of my old universal remotes to trigger the shutter, so I can do MUP shooting. What would really help, however, would be to have just ONE blessed night out of 25 be clear overhead.
12-24-2018, 10:59 AM - 1 Like   #22
QuoteOriginally posted by jawats Quote
Bob,
That's a very common problem which has a solution - use a special tripod that comes with an airplane ticket to Arizona or some parts of Africa. I hear you!
12-24-2018, 11:21 AM   #23
Bob,
You just might be on to something there. I was thinking of something crazy, like hopping an Allegiant air flight from here in South Bend to someplace like Phoenix, for a weekend of photography.
addition, alta, approach, astrotracer, ball, ballhead, camera, cameras, customer service, davis, eq, fluid, goto, head, kit, lens, motion, photography, ricoh imaging, sanford, stable, star, suggestion, targets, tripod, tripod and ball, tripods, vanguard
Need help figuring out tripod and tripod head for k3 II Infinite Ascension Troubleshooting and Beginner Help 32 03-27-2018 07:05 PM
Tripod Strap vs Tripod Bag vs Nothing At All reivax Pentax Camera and Field Accessories 16 01-10-2012 07:58 PM
what's the difference between a cam tripod and umbrella/flash tripod? mike.hiran Flashes, Lighting, and Studio 11 06-23-2009 06:56 PM
Tripod head stuck on my tripod... Buddha Jones Pentax Camera and Field Accessories 11 06-04-2008 07:34 PM
to tripod or not to tripod THAN THE SWORD Pentax Camera and Field Accessories 3 07-11-2007 04:53 PM
All times are GMT -7. The time now is 02:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
