Originally posted by builttospill Thanks for testing this for us and reporting back. The parts that weren't broken, how did they function? Did you like them?
Well... I wanted a tripod that allows the centre column to move outwards and away, so that i can shoot items directly from above (like food), productphotography etc. It seems that the tripods do get quite a bit heavy and expensive for this feature, which I can understand as you will have some lever issues and weight imbalance, so the tripod itself felt very 'meaty'.
However, it could extend very high indeed, and with only 2 twist locks per leg and small turns you could set it up fast! However, folded right down it was still quite large indeed. It comes with a bag, intended to be worn by the user in a sling style and you would need this, I'm not sure at all how you could strap the tripod onto a backpack easily, it's quite large even in its most compact form. I guess you can't have it all (quick set up, heavy duty, light and compact). Or maybe you can but they cost thousands lol.
