02-17-2020, 03:50 AM   #31
Seeker of Knowledge
aslyfox's Avatar
I am not a doctor or physical therapist, nor have I ever played on on stage or screen, large or small
those looking for back pack might have to look at things such as hip belts, sternum straps and load lifters
Backpack Sizing Guide | How Should My Backpack Fit | Gregory
https://www.rei.com/learn/expert-advice/backpack.html
_________________________________________
when ever I buy a back pack I first look for features that makes the pack useful for carrying any type of load such as
(1) hip straps: The majority of a backpack's weight, 80 percent or more, should be supported by your hips.;
(2) Load Lifter Straps: These are stitched into the top of the shoulder straps, and they connect to the top of the pack frame. Ideally, they will form a 45 angle between your shoulder straps and the pack. Kept snug (but not too tight), they prevent the upper portion of a pack from pulling away from your body, which would cause the pack to sag on your lumbar region and
(3) Sternum Strap: This mid-chest strap allows you to connect your shoulder straps, which can boost your stability. It can be useful to do so when traveling on uneven cross-country terrain where an awkward move could cause your pack to shift abruptly and throw you off-balance.
then I look for special features for the expected use of the back pack: in this one, the interior has the loop and hook dividers so you can personalize the interior as you choose, multiple external attachment points and pockets, a " rain " cover and a separate padded section for a lap top or something else
I have several different back packs, here is the review for the largest one:
https://www.pentaxforums.com/accessoryreviews/ruggard-thunderhead-75-dslr-am...head-75-d.html
if possible find a good store selling high line back packs and try some out
then if you don't want to modify such packs for camera use
look at camera bags offering such options
check here:
Backpacks - Pentax Camera Accessory Review Database
airport, bag, break, camera, camera bag solutions, car, gear, laptop, office, photography
What's Your Favorite Camera Bag That Looks Nothing Like a Camera Bag? reivax Pentax Camera and Field Accessories 19 10-19-2017 07:09 PM
Geriatric 6x7 jwmanthorpe Welcomes and Introductions 2 04-09-2017 12:23 AM
B+W circular polarizer filter is that it does not rotate freely. Any solutions? Theov39 Pentax Camera and Field Accessories 8 12-25-2016 07:36 AM
People Geriatric photo Talete Post Your Photos! 0 06-03-2014 11:51 AM
Is there a auto-lens retraction setting for when camera is turned off? harioharima Pentax K-01 10 02-21-2013 05:27 PM
All times are GMT -7. The time now is 12:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
