03-21-2019, 02:35 AM   #1
Liney's Avatar
Bolt size
I know this is probably a very stupid question, but can anyone tell me the specs of a bolt that would fit the standard camera tripod mount?
I've just picked up a set of bellows, I want to mount it to a flat surface using the tripod mount and to save me walking up and down the aisle in my local hardware store trying everything that looks like it might fit, I thought I would ask.
Cheers
03-21-2019, 02:41 AM - 1 Like   #2
Seeker of Knowledge
aslyfox's Avatar
well reversible adapters are 3/8" to 1/4" or the reverse
Promaster 3/8" to 1/4" Tripod Thread Adapter
Sunmns 1/4 Inch and 3/8 Inch Converter Threaded Screws Adapter Mount Set for Camera/Tripod/Monopod/Ballhead/Light Stand/Shoulder Rig, 21 Pieces
does that help ?
03-21-2019, 03:08 AM - 2 Likes   #3
1/4" by 20 threads per inch is the most common
03-21-2019, 03:36 AM   #4
Liney's Avatar
Thank you both, much obliged
03-21-2019, 06:04 AM - 1 Like   #5
jumbleview's Avatar
As far as I remember in the USA it is 1/4 coarse thread.
03-21-2019, 10:09 AM - 1 Like   #6
Wheatfield's Avatar
QuoteOriginally posted by Liney Quote
Cheers
1/4"x20
03-21-2019, 10:41 AM - 1 Like   #7
Robot camera's Avatar
It's known over here as a 1/4" Whitworth bolt. Whitworth were the first standardised thread form, in 1841. I'm pretty sure the bigger tripod screw is also Whitworth, 3/8". More recently these sizes have been re standardised as UNC threads; the same number of Threads Per Inch, (20 tpi and 16 tpi respectively) but the screw thread has 60 degree sides instead of 55 degree ones. In practise it probably makes little difference, but you may be able to find UNC bolts more easily; the bolt is only done up finger tight, after all.
If you have to order this stuff, a bolt doesn't have a thread that goes all the way to the head, a set screw does. This cork sheet looks useful for stopping things from swivelling about, though I haven't yet tried it myself. You'll have to do a search in your own country. (I see you are in Australia)
Taps and dies to clean, cut or extend threads for all these sizes are easily available for either, at least in the UK, and I find them useful for making various brackets. Don't buy the ones that are "for restoration". They are cheap for a reason.
03-21-2019, 11:40 AM - 1 Like   #8
jumbleview's Avatar
That one would fit for sure:
1/4 Screw with D-Ring - for Cameras / Tripods / Photo / Video ID: 2629 - $1.95 : Adafruit Industries, Unique & fun DIY electronics and kits
03-21-2019, 12:05 PM - 1 Like   #9
Otis Memorial Pentaxian
1/4-20 ANSI...equivalent to 1/4 UNC (UTS) for the more common smaller size...
3/8-16 ANSI for the less common larger size...
Some older British-made stuff may be Whitworth, but anything recent or made for import to the U.S. would be ANSI.
bolt, photography, tripod
Bolt Macro Light at B&H for $40-12/31 only bladerunner6 Pentax Price Watch 2 12-31-2017 08:31 AM
Bolt ring flash $59;12/7/17 bladerunner6 Pentax Price Watch 10 12-07-2017 09:08 PM
For Sale - Sold: Bolt Battery Pack for Cactus RF60, some Canon, & Bolt VX flashes PRICE DROP comprock Sold Items 3 07-05-2016 02:48 AM
For Sale - Sold: Pentax K-x, Bower 14mm f2.8, Vivitar 28mm f2, Vanguard Ballhead, Bolt Flash, +more krp Sold Items 6 06-08-2016 04:06 PM
Bolt VS510 Flash and K30 rsie Troubleshooting and Beginner Help 2 01-22-2014 01:49 AM
All times are GMT -7. The time now is 12:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
