Originally posted by stevebrot Digging around my father's old stuff and I found what appears to be an unbranded remote just like what you show, it's identical except for the 'Bower' brand print.
It terminates with a 2.5mm female, I don't seem to have the original cable to connect to the K-1, I used a few adapters and what not and eventually docked into the k-1 successfully however I can only fire the shutter, half press AF is not working, is there something I'm missing?
Basically, pretend all of my cables are not compatible, if I want 5m cables to work from this remote for the K-1 and KP, which ones do I need? Does it matter if some are stereo, mono, three and four connections?
Originally posted by Riggomatic There's this option:
amazon.com : Pixel 2.4GHz Digital Wireless Remote Shutter Release E3 for Canon, Pentax, Samsung, Contax, Sigma and Hassleblad Cameras, Replaces Canon RS-60E3 : Camera & Photo?tag=pentaxforums-20&
You half press the button to focus, full press for shutter,
but you need to enable half press shutter release on the camera for the focus to work from the remote.
Receiver can hang from the cable if you are using an external flash, or clamp to the hot shoe if not in use.
You can buy a longer cable, and use the button on the receiver to actuate focus and shutter.
It doesn't require line of site to the camera, and has a decent range.
I use mine on the K-5.
How do you do that? This might be what is stopping me from using Stevebrots remote with AF...
I like the idea of this, because then we could do more family selfies in bright conditions more successfully (without a cable leading to the group of people).
I do however need this remote quickly, the Amazon link you show would take too long.
Do you think this would work?
Vello FreeWave Wireless Remote Shutter Release Kit RW-O2K B&H
It's quite a bit more expensive, however it should arrive in time. I'm thinking it's different in that it's Radio Frequency rather than digital wireless, which is better?
EDIT: PS, one of the reasons I need a proper remote and not the Image Sync app is that I don't think I can get it to do Face Detection AF. Face Detection is excellent, and in a group setting stopped down it doesn't matter which face it singles out really, the ONLY gripe I have with the IR remote I already have is in bright conditions it just can't see the signal well enough. That's why I just want AF and shutter really, set the camera up for Face Detection in Live View, get in a group, focus (hear the focus confirmation), stay still and take the shot (even use a 3 sec delay etc to remove the remote out of the way). It's how I took this family shot;
No idea whose face Face Detection chose, but it doesn't matter as it's stopped down enough. I simply want this but to work in sunny outdoor Australia (and using flashes as well).
