Originally posted by RGlasel Ithink the problem you will run into is that the circuits for triggering a flash are used for communicating with the O-GPS unit ...
I doubt that. Any dumb flash, like my modified early Vivitar 283 flashes, can be triggered by the camera connecting the center pin to the hot shoe base. The communication between the camera and a TTL flash, or between the camera and the O-GPS1, are almost certainly using the three other pins on the shoe, perhaps with the shoe base as ground. Pentax probably used a readily available GPS chipset that sends serial data, perhaps in NMEA format, to the body. Communications go in the other direction with the flash, the camera body telling the flash what it needs to do, also probably in serial format. I strongly suspect that the center pin plays no role in either.
---------- Post added 05-24-19 at 03:09 PM ----------
Originally posted by Pentax Syntax I think you can use this if you can find one ...
That is the sort of thing that should work - I will look around and see what is available.
---------- Post added 05-24-19 at 03:17 PM ----------
Originally posted by stevebrot How about something like a universal pass-through adapter with PC sync out?
That should work but the pin pattern does not appear to match that of the K-70 hot shoe, so the O-GPS1 probably would not work with it.
Originally posted by stevebrot ... mixing speed lights and P-TTL flash on the same circuit may not work well.
I will not be mixing them. The idea is to use the GPS and my wireless off-camera flash trigger transmitter at the same time (the transmitter can be mounted off of the hot shoe and cable-triggered from a standard flash sync jack). The off-camera flashes are dumb and manually set - no TTL involved.
---------- Post added 05-24-19 at 03:19 PM ----------
Thanks for all of the ideas, folks. That's why I asked here - to get ideas on what to look for and where to look at it.
