Originally posted by stevebrot Not to be a spoil sport and I do love good lower-priced gear, but how is the water resistance of this case? Have any of you owners tested it on the water with dummy weight for ballast?
I would not ask except that I was on a white water rafting trip several years ago where one of the rafters had a Pelican-type case leak badly ruining a digital camera and other kit. Water literally poured out when the latch was released.
For many of us, never going near water; I would not need extreme water resistance in a case.
However, the 5800 is rated IP 65 watertight:
"IP65 Enclosures
Able to protect against water jets
Water projected by a nozzle (6.3 mm) against enclosure from any direction shall have no harmful effects.
Test duration: at least 15 minutes
Water volume: 12.5 litres per minute
Pressure: 30 kPa at distance of 3 m"
