Originally posted by 3by2 Weight, size, flexibility, height what do you think are important in a travel tripod?
We need to know more about your photography to make good recommendations.
What camera and lenses will you be using? Heavy lenses and long telephoto need a more sturdy tripod to prevent shake.
What form of "travel" will you be doing? For multiday backpacking weight might be your most important concern, and then saving a few ounces/grams with carbon fiber might be worth the extra cost. If traveling mostly by car then the extra weight of aluminum probably doesn't matter.
Will you be doing any night or other long exposure photography? 30 second exposures need a very stable tripod. There are tricks, such as hanging your camera bag from the bottom, to increase stability.
Do you have a preference for twist-lock or flip-lock legs? Some people have strong preferences but I do not. Twist-lock takes a fraction more time to use IMO. Flip-lock is a little bulkier.
I've had good experiences with a Sirui travel tripod. It's small enough to fit inside my camera bag. It's held up well for several years, in spite of sometimes being used in gritty sand and corrosive salt water. Here's the closest current model to what I have:
Sirui A1005 Aluminum Tripod with Y-10 Ball Head SUA1005Y B&H.
